speedball1978 Posted January 31, 2011 Report Posted January 31, 2011 Anyone want to help me figure out how to step up my voltage. Here's what i have currently d1200 under the hood, DC Power 320 HP alt, xs power d3100 in the back.. i'm reading a steady 14.7 and drops to maybe around 14.4 14.5 but i would like to increase this voltage up to 15.7 15.8 without reaching the 16v which would require a step down. Do i need to get a VCM? MLA module?, do i need to send the alternator back to have the set point customized... i don't have a budget...its a 2009 chevy malibu LT2 2.4 4 cyclinder
n8ball2013 Posted January 31, 2011 Report Posted January 31, 2011 willing to bet a vcm or mla wont help you and that the voltage is controlled by the computer. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Guest Posted January 31, 2011 Report Posted January 31, 2011 willing to bet a vcm or mla wont help you and that the voltage is controlled by the computer. i was under the impression that you could attach an mla or vcm even if the car's voltage was controlled by the ECU
speedball1978 Posted January 31, 2011 Author Report Posted January 31, 2011 willing to bet a vcm or mla wont help you and that the voltage is controlled by the computer. i was under the impression that you could attach an mla or vcm even if the car's voltage was controlled by the ECU this is what i had assumed i've contacted xs power, mla, and mechman.. got different results and read up on info using google.. if anyone could help me out .. it would be great
osamio Posted February 1, 2011 Report Posted February 1, 2011 willing to bet a vcm or mla wont help you and that the voltage is controlled by the computer. i was under the impression that you could attach an mla or vcm even if the car's voltage was controlled by the ECU this is what i had assumed i've contacted xs power, mla, and mechman.. got different results and read up on info using google.. if anyone could help me out .. it would be great They didn't offer you a bypass type solutino? usually the ECU requires some type of feedback, but i'm pretty sure there are VCM's that bypass/emulate it.. **Edit *solution 2009 Cobalt LT Pioneer Headunit 2x Pioneer 6 1/2 (stock amp) 2x Pioneer 1" tweeters (stock amp) 2x Pioneer 6x9 (stock amp 4x Pioneer 6 1/2 Pioneer GM-6400F Soundstream DTR 1700 R.I.P 2x Champion series PRO 12" subs 0 AWG Big 3, Stinger SP1700 battery To come: New or repaired DTR!!
