MistahVee502 Posted February 2, 2011 Report Posted February 2, 2011 I have Two 12" HiFonicHFi12D4's being ran by a 600W Peak Rockford Fosgate 201s. Whenever I run one 12 by itself its running somewhere around 300Wrms and sounds GREAT but when I try running them both at the same time they both sound bogged down(like they are both pulling from the same 300Wrms that the one was drawing from instead of splitting the 600W peak). I reall would like to figure this out...have been running one sub for quite a while now and would like to get stuff in right working order. Please Reply ASAP. Thank You Also, I have checked all the wiring throughout the car besides whats under the carpet, My battery is brand new, and the subs are brand new as well. -Vee THE YOTA(96'Camry LE) Her Voice: Kenwood KDC-MP345U Receiver Two 12" HFi12D4 Subwoofers Rockford Fosgate 201s Amp Four Kenwood Excelon KFC-X693 6x9s
CJ18 Posted February 2, 2011 Report Posted February 2, 2011 This is because your amp is only putting out 300w tops. When a company rates an amp for peak output, this is with a fully clipped signal. I have a Kicker Warhorse that is capable of putting out 20000w peak, but only does 10000w rms. When buying an amp you need to always look at the RMS rating not the PEAK rating.
michigancapri92 Posted February 2, 2011 Report Posted February 2, 2011 dont go by peak, what ohm is the sub, are you running the subs series? parallel? if amp puts out 300W 40hms and you have subs wired 8 amp will only put out 150, check your ohm loads and RMS!!!!!rating of the amp Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
MistahVee502 Posted February 2, 2011 Author Report Posted February 2, 2011 This is because your amp is only putting out 300w tops. When a company rates an amp for peak output, this is with a fully clipped signal. I have a Kicker Warhorse that is capable of putting out 20000w peak, but only does 10000w rms. When buying an amp you need to always look at the RMS rating not the PEAK rating. Oh ok...Thank You. Do you have any good amp suggestions for my setup that wouldnt be too hard on my pockets? something that will push my subs to their rightful limit THE YOTA(96'Camry LE) Her Voice: Kenwood KDC-MP345U Receiver Two 12" HFi12D4 Subwoofers Rockford Fosgate 201s Amp Four Kenwood Excelon KFC-X693 6x9s
michigancapri92 Posted February 2, 2011 Report Posted February 2, 2011 dont go by peak, what ohm is the sub, are you running the subs series? parallel? if amp puts out 300W 4 0hms and you have subs wired 8 amp will only put out 150, check your ohm loads and RMS!!!!!rating of the amp Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
CJ18 Posted February 2, 2011 Report Posted February 2, 2011 To get the performance you expect out of your subs, you need to either purchase a second identical amp to the one you have, or purchase a 600w RMS amp.
michigancapri92 Posted February 2, 2011 Report Posted February 2, 2011 double post sorry Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
CJ18 Posted February 2, 2011 Report Posted February 2, 2011 What is your budget for an amp? For what you are running and looking for, I would look into power acoustik. It is not a great brand but for low powered applications, it works jsut fine and is not hard on the wallet. Look at the gothic series.
MistahVee502 Posted February 2, 2011 Author Report Posted February 2, 2011 To get the performance you expect out of your subs, you need to either purchase a second identical amp to the one you have, or purchase a 600w RMS amp. So we are talking something like a 1200w Amp Peak 600w rms? THE YOTA(96'Camry LE) Her Voice: Kenwood KDC-MP345U Receiver Two 12" HFi12D4 Subwoofers Rockford Fosgate 201s Amp Four Kenwood Excelon KFC-X693 6x9s
Rebel4055 Posted February 2, 2011 Report Posted February 2, 2011 Don't look at the peak rating at all. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
