i can get an optima redtop for $100 new and i was wondering if it'd be better to put in the back of my blazer with my stock battery up front,or just do away with the stock one and put it up front,and also since im only running an a3000db if i run the optima in the rear can i use just a positive run off the battery or will i also have to do a negative,i was thinking just a positive run and ground the battery to the chassis and amp to battery?
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
how much power or shall i say what's the total RMS of your system?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Guest MegaloManiac
put the red up front. be done with it. sealed gel cells battery really shouldnt be linked with a lead acid liquid battery.
Look out its Nordic the Thread Jacker!
I have a redtop laying around, and its hasent been charged for a while! And when i used a P.O.S charger the charger just went into "protect" and didnt want to charge anymore, should i try another charger or contact the shop i baught it from!?
Hertz - Pioneer - Zealum
Guest MegaloManiac
if its under warranty(red top comes with 3yr i believe) take it back and get a new one. if you want to use a charger use one that will Condition the battery and charge it, like meades powermaster
not 3 year replacement, but 3 year prorate FTL!!! if you got your purchase date i'll be happy to calculate proration for you. :)
Barretto MotorsportsTeam RFCTeam CHMTeam SMD "Blow Sand"Live Your Life Without Boundaries... http://www.jeffbarretto.acnrep.com/d_oppor...A=US_EN&BW=
yep this batteries need slow chargers too i dont think theyre good with fast chargers
quick question is it ok to have a blue top under the hood since its a marine battery??, cause thats what my car has
it'll be bewteen 2300 -3000rms and i'd like to keep the the stock alternator,just thought i could do one in the front and on or two in the back if needed,i was gonna go kinetik in the rear i still might
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
  • Who's Online   0 Members, 0 Anonymous, 4925 Guests (See full list)
