Jagraj7870 Posted February 3, 2011 Report Posted February 3, 2011 Amplifier= Kicker 10IX500.4 4-Channel Class D Car Amplifier Power Output (in RMS): 4 ohms: 75 watts x 4 channels 2 ohms: 125 watts x 4 channels 4 ohms bridged: 250 watts x 2 channels Peak Power Rating: 500 watts RMS Speakers= Kicker 08KS650.2 6.5" 300 watt (150 each) component speakers (im a get 2 sets) 150 Watts peak each speaker (300 watts total per pair) 75 watts RMS each speaker (150 watts RMS per pair) 6 1/2" woofer 1" Tweeter 4ohms would this amplifier be a good decision? only thing im confused about is the tweeters? are they in 1 channel or are they separate(like are they included in the 75 watts or are they also 75 watts, so intotal one side is 150 watts?) thanks - 2 SMDs 1 Kicker WarhorseSound System Build Log: http://www.stevemeadedesigns.com/board/topic/120796-2-18s-in-jeep-wrangler-jk-w-kicker-amplifiers/Air Bag Build Log: http://www.stevemeadedesigns.com/board/topic/166437-jeep-wrangler-bagdj10k-build/https://www.facebook.com/teammayzn
hdorre Posted February 3, 2011 Report Posted February 3, 2011 Yeah, they'll work well with eachother. Each component set includes 2 crossovers. Each crossover uses its own channel. One mid and one tweet connect to each crossover. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
LordArcane Posted February 3, 2011 Report Posted February 3, 2011 they come tweets and mids hooked into cross over each hooking to their own spot, the cross over has 1 input aka from your amp, to answer your question yes that amp and those speakers should work fine. and you really answer your question, the tweets are 75rms and so are the mids. in depth is cross over sends only freq "a" and above to your tweets at 75 rms and then send freq "b" and below to your mids at 75 rms. hope that helps you out
Jagraj7870 Posted February 3, 2011 Author Report Posted February 3, 2011 they come tweets and mids hooked into cross over each hooking to their own spot, the cross over has 1 input aka from your amp, to answer your question yes that amp and those speakers should work fine. and you really answer your question, the tweets are 75rms and so are the mids. in depth is cross over sends only freq "a" and above to your tweets at 75 rms and then send freq "b" and below to your mids at 75 rms. hope that helps you out o alright thanks for the clarification. - 2 SMDs 1 Kicker WarhorseSound System Build Log: http://www.stevemeadedesigns.com/board/topic/120796-2-18s-in-jeep-wrangler-jk-w-kicker-amplifiers/Air Bag Build Log: http://www.stevemeadedesigns.com/board/topic/166437-jeep-wrangler-bagdj10k-build/https://www.facebook.com/teammayzn
Dj_Scarface Posted February 3, 2011 Report Posted February 3, 2011 YUP... It will work look at the RMS numbers Working on my 93' Ford Bronco rebuild:I have:pioneer AVH-P6500Infinity Reference 6032SI frontsInfinity Reference 6832CF Rears Crescendo CZ 6.5 kicks Crescendo 1100.4 (2) DC Audio LvL 4 M2's (1) Juicebox BlackcherryPiece together amps & wiringBout to get:Crescendo Amps Crescendo Mids Crescendo Tweets Sky High Car Audio Wire Rockford Fosgate 360.2 or .3 My Buildhttp://www.stevemeadedesigns.com/board/topic/97426-93-ford-bronco-rebuild-full-system-body-paint/
