hey im getting loud popping noises from my speakers and sub when i take out the key out of the ignition. also im getting some kind of static noises from my front speakers. does anyone know what is causing this?
iDA-X200/Clarion EQS746
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Alpine & Polk Speakers
Stock electrical
Could be a bad ground.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
i lowered the gain on the 4 channel it made the noise go away a little. right now i just installed a clarion eqs746 and a idax100 together.
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
Try a piece of cable and wind it around the rca and ground it if u get what i mean
Had an estimate of 6400 for an alpine/clarion setup dealer said it "should" hit around 160db with the custom boxes he was going to make for me..doubtful with so much area to move but, budget is way below that :( any ideas on cheaper brands for that kind of Spl setup? really didnt want to try any Boss or soundstorm, thinking Quantum figure around $150 per speaker "$1800 total" and $1700 to power it, first actual big setup for the van.
New MEMPHIS CAR AUDIO build
4 15s Memphis C3
2 xs power D3100
1 xs power d3400
custom fiberglass door pannel
and lots more
My Build
the popping is a ground issue..
use the same wire as you did the power. even if you cant get it in another color
"yes... it will play like that all day!"
this never happened until i installed the new deck the EQ...this never happened when i just had the deck by itself.
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
Agreed with this. After installing my 4chan I had the same "static" engine noise, and it was horrible. Stripped the insulation off some wire I had laying around, wrapped it around my RCAs, grounded it to my H/U, then another wire coming off that ground to my frame. Noise went away.
Also had popping noise from my sub when I would turn the car off, that was quick and easy fix, accidentally put the RCAs backwards on my sub amp. :shrug:
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
how will i wrap the wire around the RCAs? will i need to solder it?
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
  • Who's Online   0 Members, 0 Anonymous, 5106 Guests (See full list)
