soundstream15 Posted June 18, 2013 Report Share Posted June 18, 2013 A guy on here is selling one, and my friend doesn't know to much about them, I don't either. Are they good? Do they do rated and are they solid amps? It's the older model crunch Link to comment Share on other sites More sharing options...
n8ball2013 Posted June 18, 2013 Report Share Posted June 18, 2013 consider it a hifonics. These were actually decent amps a few years ago. not spectacular. but decent. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Trey_Dog650 Posted June 18, 2013 Report Share Posted June 18, 2013 Will do rated 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head. Link to comment Share on other sites More sharing options...
Omega5002 Posted June 18, 2013 Report Share Posted June 18, 2013 Here's the guts 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
TRTC360 Posted June 18, 2013 Report Share Posted June 18, 2013 many people say that's the last good amp that came out of maxxsonics production. '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360 Link to comment Share on other sites More sharing options...
soundstream15 Posted June 18, 2013 Author Report Share Posted June 18, 2013 Well I thought about getting rid of my AQ 2200 for this. I know it's maxxsonics but I think decaf had this amp.. Link to comment Share on other sites More sharing options...
soundstream15 Posted June 18, 2013 Author Report Share Posted June 18, 2013 Seems like a solid amp. Just not sure if its better then AQ2200 although fuse raitin is 300amp for the crunch AQ is 200 Link to comment Share on other sites More sharing options...
soundstream15 Posted June 18, 2013 Author Report Share Posted June 18, 2013 Can anyone else give info Link to comment Share on other sites More sharing options...
soundstream15 Posted June 18, 2013 Author Report Share Posted June 18, 2013 Well guys. I'm gonna get this amp. Did research and someone clamped this amp and this is what I found. Also it's the same board as the AB 200.1 and a few other amps, it's a little beefier then my AQ2200 Quote: Ok guys, here it is. Depending on your battery set up this amp will make an ungodly amount of power. With a 12volt battery set up dropping to 11.5 volts the Crunch GP3000D Pro made 2850 watts at a 1.03 ohm reactive. That's 4 12volt batteries. If you can get the voltage up the amp will make much more. By just starting the car and using the high amp alternator (starting at 16.1 volts and dropping to 12.3volts), the 3000 made 3732 watts. That's crazy isn't it. THAT'S NOTHING! I hooked it up to a 16volt battery set up and it just went crazy! With the battery voltage dropping to 15.7 volts with a 1.4 ohm reactive this monster made 4640 usable watts. NOW WHAT DO YOU THINK ABOUT THAT! Link to comment Share on other sites More sharing options...
