Hey guys. I was changing my ground to a new/better location and now my amplifier will not turn on. No power led or protect led is lit when vehicle is on. I have the REM jumped to the power to check to see if it would work. That is not the case however. I checked the voltage before and after the fuse. Both sides show 14.5v. However, when I check the voltage at the amplifier, it only reads 2.4v. That's not normal is it? When I remove the power wire from the amp the voltage shows 14.5v while vehicle is running. However, when I check the voltage at the amplifier (power wire plugged in), it only reads 2.4v. That's not normal is it? Is my amp fried?
*Side note* All three 40 amp fuses are not blown on the amp either. Thanks.
Vehicle: 2013 Ford F-150 STX SuperCab 5.0L V8 4x4
BIG 3: Knukonceptz Kolossus Fleks 0 Gauge OFC Power Amp Kit
Headunit: Stock (Leaving factory look)
Speakers: Stock
Subwoofer: Incriminator Audio Lethal Injection 10" D2 wired down to 1 ohm
Enclosure: ~1.5 cubic feet tuned to ~34 Hz (Port Area ~24 inches)
Amplifier(s): Sundown Audio SAE1000.1D
Amp Power Kit: Knukonceptz Complete 4 Gauge OFC Amplifier Installation Kit
Anyone???
Speakers: Stock
Anyone???
Check your ground. Take pics and post them of your new ground.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
lots of sky high cable
dual alts(came off the sky-high gmc and don't know who made them)
ipad in center console
vu-din in center console
all being ripped out and being sold
Yes. I checked with a mutimeter. I get 0.2 to 0.3 ohms with the new ground. The ground is connected to a bolt that holds down the seat on the front. Will post pics when I get home.
Speakers: Stock
seat belt grounds are generally a terrible place to ground to due to the dirtiness and rust build up those connections can have. Checking resistance with a volt/ohm meter is all find and dandy but that ohm load would be the same if only one strand of wire was touching a ground point. Only way to fully check that the ground is good is to test it's continuity loaded.
I would rather use a self tapping screw and star washer on bare cleaned metal than go to a seat belt bolt.
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
It's not a seat belt bolt. It's a bolt that holds the seat to the cab of the truck. But Thanks for the tip.
Speakers: Stock
Still the same thing applies.
If you have a truck why aren't you grounding it to the frame?
Edited by Broke_Audio_Addict
those are also not good because they're usually covered in loctite from the factory. loctite is a good electrical insulator. did you check the resistance between the amp ground and the battery low post with everything hooked up?
Cables and wires almost never fail; the terminations do.
  • Who's Online   1 Member, 0 Anonymous, 445 Guests (See full list)
