BoomZoom808 Posted May 29, 2016 Report Share Posted May 29, 2016 Some of you might know I was given an NVX VCW 124 from the awesome guys at SonicElectronix as one of the cool contests that happen here at SMD. Some of you migh be wondering whatever happened to that sub? Well I still have that sub and was planning to use it in my build I am slowly working on as part of a mild SQ setup. I finally got around to starting to do the install and testing and tuning and have run in to some issues with the sub. Which hopefully are a fluke and can be addressed. The design I chose for the box was on the large size 2.75 cubes tuned to 34hz with around 34 ^ 2 of port area. The sub suspension and coil have held up pretty good but where the problem lies in my opinion is the adhesive NVX uses. The sub started to sound like it was unloading or bottoming out when testing in the box. So I took it out to do some free air testing. The test was performed using the DD tone generator my JVC headunit and a Rockford P1000X1D with the coils wired in parallel for a 2 ohm load. The voltage strong during the entire test 14.4-14.2 volts very little to no voltage drop during the test. I was puzzled at first as their was no coil rub and the coils did not appear to be black. Then I took a closer look at the dust cap. ah ha it's just the dust cap coming off a simple and easy fix or so I thought. After removing the dust cap and further testing the motor noise still remains and it looks like the same adhesive may have been used for the triple joint. I just wanted to share my findings and I am kinda bummed but still thankful to have been able to test this sub. 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12 Link to comment Share on other sites More sharing options...
audiolamb6 Posted May 29, 2016 Report Share Posted May 29, 2016 so is the triple joint failing also maybe post a video so we get more i put on the problem Link to comment Share on other sites More sharing options...
BoomZoom808 Posted May 29, 2016 Author Report Share Posted May 29, 2016 Can't really see any visible damage I'm thinking the bottom spider is coming off the coil 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12 Link to comment Share on other sites More sharing options...
BoomZoom808 Posted May 30, 2016 Author Report Share Posted May 30, 2016 Not sure if you can hear it in this video 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12 Link to comment Share on other sites More sharing options...
