Setting gains without a deck/head unit?
How do I properly set the amp gains using the DD-1 without a deck with volume numbers to use as reference for distortion? I have an iPad as the only source going from the 30 pin to rca to an Audio Control Three.2 EQ to my amps.
I have searched but found nothing that will help me out. I found Steve's Youtube vid showing how to adjust the gains with an iPad as the source but he was running through a deck where the volume numbers were used for reference.
Edited by JP Fabrication
How are you going from ipad to three.2?
3.5mm to RCA?
Just work your way back from the source checking rca outs along the way for distortion.
Thats how i did it with my istreamer and matrix+ in my set up.
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
30 pin to RCA
So my guess would to use painters tape to cover the EQ volume knob and the face of the EQ all the way around the volume knob and make reference marks on both the knob and eq when distortion kicks in?
put dd-1 on rcas coming from 30 pin->
play whichever track you need, and turn volume on ipad up until you see distortion, record that volume->
plug rca's into eq, play track at recorded volume from earlier step, and set any gains on eq (note: if the knob for the eq is a remote gain knob, turn it to it's full setting while you are setting the gain)->
input rca's into amplifier, turn ipad to recorded volume, turn knob taking in account previous note, and then set amp gains
Edited by Jhunt94
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
Put the test track in iPad
Check your max limit through the rca
Then out the 3.2 eq
Then out the amp
For the eq reference I would mark the knob and max turn point before clipping
I would set it and for get it on the eq
beat me to it lol
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
  • Who's Online   0 Members, 0 Anonymous, 1619 Guests (See full list)
