rfbasshead Posted October 23, 2016 Report Share Posted October 23, 2016 so on Wednesday i was listing to talk radio and i heard a sizzle and then boom, up in smoke this went. im in the process of either repairing or replaceing and before i throw something else in there i want to fix what ever broke this. im running 6 10 in p3 in a 4th off this t2500 a t400.4 t1 comps in the front t1 6x9 in the back, a singer 370 a duralast agm up front a xp3000 an a d2700 in the back. 2 runs from the front to the back and 2 dedicated grounds to the frame up front and in the back as well using all shca ofc 0awg Link to comment Share on other sites More sharing options...
rfbasshead Posted October 23, 2016 Author Report Share Posted October 23, 2016 Link to comment Share on other sites More sharing options...
rfbasshead Posted October 23, 2016 Author Report Share Posted October 23, 2016 this is all the damage i found. theres like some sort of something on the board. i tried to get it in the pics as best i could. you can see where i was wiping it Link to comment Share on other sites More sharing options...
Jessica Posted October 23, 2016 Report Share Posted October 23, 2016 what was the final ohm load? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
rfbasshead Posted October 23, 2016 Author Report Share Posted October 23, 2016 1.33 and honestly i ran it. like RAN it. it was on for like 8 hours a day 5 days a week and i was playing full tilt about 60-70% of that time. i had fans on it to keep it cool, but it wasnt under any load when it went up. i was listing to talk radio... Link to comment Share on other sites More sharing options...
rfbasshead Posted October 23, 2016 Author Report Share Posted October 23, 2016 gain at like 6-7 out of 11 Link to comment Share on other sites More sharing options...
RainStryke Posted October 23, 2016 Report Share Posted October 23, 2016 gain at like 6-7 out of 11 A lot of amplifier's i've set with the DD-1 and seen set with the DD-1 start clipping after about 30-40% gain... it's likely you were clipping bad and finally it gave out. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted October 24, 2016 Report Share Posted October 24, 2016 Talk radio. Not the first time I have heard of this. I don't know why exactly. I forget the exact term but it is like old recordings that have little to no bass. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted October 24, 2016 Report Share Posted October 24, 2016 You were clipping it to death. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
audiofanaticz Posted October 24, 2016 Report Share Posted October 24, 2016 Talk radio. Not the first time I have heard of this. I don't know why exactly. I forget the exact term but it is like old recordings that have little to no bass. This. I know what your talking about but I do not recall it 100% It has to do with how Class D amps work with the output being a high frequency square wave output that is pwm controlled by the input signal of somewhere around 500Khz or higher. When the input is seeing no signal the amp is going nuts trying to sample the signal that is not there so its trying to compensate for that signal and boost it higher and overworks itself until the amp either blows or your fuse blows from to much current draw (whichever comes first). Due to the crossover limits on the amp you never hear these high pitched frequencies being played either. It kind of goes back to what Nick at Fi (ndmstang) always said about amps literally microwaving tinsel leads and catching fire.. I had this problem over and over with my pair of American Bass 150.1 amps. Just turning the volume down to 0 in the drive through while I ordered and got my food caused the amps to blow up. Was not bumping hard prior to turning it down just a moderate level, voltage was all good, as well as everything else. Leave the drive thru and turn it up a little and there is no bass, go to the trunk and nothing but smoke. Now I put my monoblocks on a switch to turn them off when I dont need them being played. Link to comment Share on other sites More sharing options...
