As previously discussed I'm working on a 1000-watt line -- I've had motor samples for some time... now I have full samples with production equivalent soft parts on the way.
As of now I still have work to do in order to dial the specs in just right -- I have another coil / gap variation to test with. I am getting a pair of samples as they sit in to test with the soft parts then I'll be testing the last variation... then likely will be ready to start making 12s at that time.
Cosmetically looks nearly identical to the SA-12 with the exception of a 20mm wider magnet, a different spider for the 3" coil, and double tinsel leads. You will note it has the new ventilation / spacer ring on it too.
This line will fill the gap from the SA series to the Z series very nicely :)
As you may have guessed by the name... this line will eventually feature a frame similar to our X-8 once all the sizes are tooled up. For now it will utilize the 4-spoke like the SA series.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
The goal is to equal or exceed the per watt performance of the SA line while also increasing power handling... with the great success of the SA series it is a bit trick to do but I think the next iteration samples should be what I need to make that happen.
12s will come first as with the SA line... then most likely 15s after that.
- Jacob Fuller
X-series FTMFW!!!
Jake? how much do these weigh?
2003 Dodge Ram 1500 - Deep Orange
Build log - Blowthrought with 4 18's http://www.stevemeadedesigns.com/board/topic/122600-4-18s-in-a-dodge-ram-team-sundown-russia/
Sundown Audio SAX125.2 - Sundown PA 10"
Shok-wiring & RCA's
XS Power D6500
Mechman 320A
Sundown Audio Russia
http://sundownaudio....dex.php?/index
http://www.drive2.ru...ram/ram/skillz/ - more about my truck
http://www.youtube.com/user/Gskillz81
and what price are they being introduced at.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Hmm if these come out before next spring I may have to get rid of my SA-12s and give these a try in my wall
Team Sundown Audio / Team XS Power / Team SHOK
SMD Super Buyer/Seller
www.sundownaudio.com
www.shokindustries.com
www.4xspower.com
www.excessiveamperage.com
  • Who's Online   0 Members, 0 Anonymous, 3002 Guests (See full list)
