Posted Image
Now you can do just about anything with it!
A little SAX-100.4 history:
SAX-100.4 -- Original model
SAX-100.4B -- Updated crossover ranges
SAX-100.4C -- Upgraded from 50-amp to 70-amp power supply transistors
SAX-100.4D -- This is the newest model
The following functionality will be had with the crossovers:
ALL CHANNELS:
Subsonic @ 10 Hz - 500 Hz (always on, can be used as the HPF for a band-pass setup in conjunction with the LPF)
HPF @ 50 Hz - 500 Hz w/ x10 button (selectable 12dB / 24dB slope)
LPF @ 50 Hz - 500 Hz w/ x10 button (selectable 12dB / 24dB slope)
So, what will you be able to do with the new model that you couldn't do before ?
1) You can bridge the amp and actively band-pass a midrange / midbass thanks to x10 functionality on both HPF and LPF on both sets of channels.
2) You can cross-over tweeters much lower with the 24 dB slopes. I have had several requests to implement this from people wanting to use planar tweeters as well, as these require steeper slopes.
3) You can experiment with overlap with the selectable slopes.
4) Most importantly for reliability and consistency... the small sub-cards that hold the crossovers will be re-tooled as double sided boards instead of single-sided. Almost all problems with previous SAX-100.4s were the result of solder problems on the single sided crossover PCB - as uncommon as these problems were we took care of the source!
All of these changes will result in a bit longer amp to fit the new crossover boards (about 1.5" longer), but will be worth it for the SQ enthusiasts who will appreciate this type of functionality.
Special pre-order price until they arrive - current ETA is 8-10 weeks or so from the date of this posting - $325 shipped in the continental 48-states!.
Contact for shipping to Alaska, Hawaii, and outside the USA.
You can take advantage of this via an authorized dealer or directly from Sundown Audio by sending Paypal to [email protected] with a note reading "SAX-100.4D pre-order"
NOTE: This pre-order is for the USA and countries that DO NOT have an authorized Sundown Audio distributor ONLY.
Edited by sundownz
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
very sweet - cant wait to get my hands on one myself
  • 1 month later...
would either be faster on arrival (after nov 21st of course or when they do arrive) date between ordering from chris @ DB-r or paypal to the sundown email listed above?
edit: is there gonna be any difference in power on the new 100.4 over the previous 100.4's?
Edited by jonnylowkon
250 amp mechman alt
Sundown 100.4D
Sundown 1500v2 now goin to the cruze
Sundown ZV3 12d2
Sundown sa6.5cs X2
Kenwood X597
Trying something new
2011 Chevy Cruze
X8
1500v2
Delivery time will be the same either way.
There will be no power difference. We upgraded the power supply in the C revision, but this was more for long-term reliability* than anything as power output was, at best, marginally increased - I expect people to be using these years from now :)
The difference for the D revision is the MASSIVE crossover update.
* - There were no problems with amps with the 50-amp FETs, but I am a fan of over-building things.
Edited by sundownz
- Jacob Fuller
Awesome ... i cant wait till ups shows up with mine!
250 amp mechman alt
Sundown 100.4D
Sundown ZV3 12d2
Sundown sa6.5cs X2
Kenwood X597
2011 Chevy Cruze
X8
1500v2
This topic is now closed to further replies.
  • Who's Online   0 Members, 0 Anonymous, 455 Guests (See full list)
