can't figure out what's wrong, when the volume and sub level is down the sub makes this noise (vid) but when i aply a tiny amount of pressure in certain areas on the cone it goes away (pic)
if i had to describe what is wrong i'd say that the motor, or coils or something is not gripping what it needs to, ima newb on the names of specific internals
when i push down on the green area the sub plays normally, when i push on the red area the bad noise get's louder.
you'll notice when i put my finger on it the errr errr errr (bad noise) goes away, because the volume on the stereo was so low, you can't hear it but the sub is working properly, just to quiet to pick up
http://s19.photobucket.com/albums/b180/aun...nt=MVI_4717.flv
what do you guys think is wrong and what should i do?
and my attempt to show some porn
http://www.youtube.com/watch?v=P9VSd_30CgQ
Edited by a_steezy
'98 Dodge Durango 5.9L
5% front windows, 2.5% on all backs
Alpine CDA-9883
Kicker ZX350.4
Kicker KS650's in all doors
Kicker 1/0 hyperflex
working on vid link right now, mah bad
Alpine CDA-9883
Kicker ZX350.4
VC out of alignment? sub cone could becoming disconnected on one side
-Drew
uhoh_45 said:
on that woofer, I would say how the cone is glued to the back piece, its a really gay design, Ive seen a few l5s and l7s with that issue, among the leads heat shrink slapping against the back side of the cone, wearing out the heat shrink, and causing the lead to slap way beyond what its supposed to
IM thinking the the coil got hot and warped and is now rubbing the wall. Sorry man.
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
only way to find out whats wrong is to take the woofer out, and look at all glue down points from spider to cone
after seeing the video, I still say its a bad glue joint between the coil and cone
thats what i was thinking..either that or the spider has come unglued..
Follow my Tweet (Twitter)
Has the sub box been bumped, dropped or moved at all? Could have knocked one of the magnets out of alignment. But for the most part it sounds like the coil is misaligned in the gap, either by warping or because the spider has got messed up somehow.
There's a slight possibility that there's something stuck in the gap too that is rubbing on one side.
10.x volts fo' life!
only problem with a magnet shifting is that it closes the gap, and catches the voice coil, and no movement at all... magnetism is a bitch
