MA HK2000
captainhook426
Look at a jbl 1200.1 or 1400.1 they do rated at 2 ohms. I have the 1200.1 hooked up to a re/fi hybrid 10 and it sounded really good
I'll keep them in mind. Which series of 1200.1 are you referring to? BP BPX? Any Difference?
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
¿ǝɯɐƃ ǝɥʇ
I had an MA HK802SX, I sold it and switched to a AQ2200(cause I was running the MA at 1 ohm with 1400rms per channel). The AQ seemed to put out the more power and sounded MUCH cleaner. I wouldn't run MA again. Just my opinion
06 300C 5.7 Hemi
K&N CAI
JVC KW-AVX640 6.1" DVD
DC Audio 3.5k
6 DC Audio 8"s
6 cubes 8" aero port at 32hrtz
http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834
at 16 or 18 volts it will. id put it a half step ahead of the ma.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
It may but looking at the manual it protects at 16volts
And the rated output is at 14.4volts
¿ǝɯɐƃ ǝɥʇ
RMS Power @ 14.4V:
* 750W x 1 @ 4 Ohm
* 1000W x 1 @ 2 Ohm
* 1500W x 1 @ 1 Ohm
RMS Power @ 17V
* 1000W x 1 @ 4 Ohm
* 1500W x 1 @ 2 Ohm
* 1800W x 1 @ 1 Ohm
Features:
* Class D / X Monoblock Amplifier
* 2000W Digital Class X Competition Mono Block Amplifier
* Thermal, Short & Overload Protection Circuitry
* Platinum Plated Screw Type RCA Jacks
* Double Sided Black Epoxy PCB Board
* Platinum Plated Block Terminals
* Fully Unregulated Power Supply
* Stainless Steel Finish Heat sink
* Quiet Fan Cooling System
* Remote Gain Control
* Full Mosfet Circuitry
* Fuse Rating: 40A x 4
* Frequency Response: 10Hz - 350Hz
* 24dB Low Pass Filter: 50Hz - 350Hz
* 24dB Subsonic Filter: 15Hz - 50Hz
* Variable 0 - 18dB Bass Boost Control at 45Hz
* RCA Input Sensitivity: 0.2 - 8V
* Low level Input Impedance: 22K Ohms
* Damping Factor: 200 @ 4 Ohm
* 1 Ohm Mono Stable
* Dimensions (W x H x D) 12.4" x 2.71" x 14.29"
* Retail Price: $899.99 / Our Price Is About 1/4 Of Retail!
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
I was seriously thinking about one of these but someone on here told me that it was kinda power hungry. I was a big fan of this when I discovered it though! Maybe I will look into them more.
RMS Power @ 14.4V:
* 750W x 1 @ 4 Ohm
* 1000W x 1 @ 2 Ohm
* 1500W x 1 @ 1 Ohm
RMS Power @ 17V
* 1000W x 1 @ 4 Ohm
* 1500W x 1 @ 2 Ohm
* 1800W x 1 @ 1 Ohm
Features:
* 1 Ohm Mono Stable
Did I miss something or was this supposed to be for the Soundstream?
RMS Power @ 14.4V:
* 750W x 1 @ 4 Ohm
* 1000W x 1 @ 2 Ohm
* 1500W x 1 @ 1 Ohm
RMS Power @ 17V
* 1000W x 1 @ 4 Ohm
* 1500W x 1 @ 2 Ohm
* 1800W x 1 @ 1 Ohm
Features:
* 1 Ohm Mono Stable
Thats the MA amp I believe the soundstream one is this one
¿ǝɯɐƃ ǝɥʇ
  • Who's Online   0 Members, 0 Anonymous, 615 Guests (See full list)
