BFF Larry Posted February 8, 2011 Report Posted February 8, 2011 can someone come up with the info, specs , amd such to help build a box that will hold two 15 inch L7s? im tryin to go for max spl. for a daily driver. heres the specs for the sub. Size (IN.,CM) 15, 38.1 Sensitivity (dB 1w/1m) 89.4 Frequency Response (Hz) 18-100 Mounting Depth (IN.,CM) 8-11/16, 22.1 Mounting Cutout, Square (IN.,CM) 13-3/4, 34.9 Min Rec Vented Box Volume (CU. Ft., Liters)** 3.0, 85.0 Max Rec Vented Box Volume (CU. Ft., Liters)** 6.0, 169.9 the box will go into a trunk of a 95 bonneville : 92 length x 51.5 width x 44.5 height @ inches thats the measurements of the trunk without including the space where ill put the amp and batts. ill need some room left to be able to take the box in and out of the trunk. i really dont want to build inside the trunk. thanks you in advance to anyone that helps me. Im a nub also and will need help in almost everything besides cutting wood, im pretty good at it. iand i dont really understand alot but would like to learn Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
BFF Larry Posted February 8, 2011 Author Report Posted February 8, 2011 anyone?? Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
BFF Larry Posted February 8, 2011 Author Report Posted February 8, 2011 bump, ill pay for someone to help make a blueprint Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
uhoh_45 Posted February 8, 2011 Report Posted February 8, 2011 how the hell do you have 7+ feet depth and 3+ feet tall in a trunk??? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
SoCaLBaMF Posted February 8, 2011 Report Posted February 8, 2011 the box will go into a trunk of a 95 bonneville : 92 length x 51.5 width x 44.5 height @ inches I dont think you have a 112 cu ft trunk Haha might want to go check those measurements again :S Edit: ninja'd 2004 Bagged Trailblazer (4)18" Sundown Nsv3s (4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4 (2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
BFF Larry Posted February 8, 2011 Author Report Posted February 8, 2011 shoot, my bad. i have to go out and measure it agian tomoro. sorry for that. but will you guys help me come up with like and image of the box and such? Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
moto211 Posted February 8, 2011 Report Posted February 8, 2011 thats a big box , not sure if it will fit CHECK OUT MY YOU TUBE PAGE http://www.youtube.com/user/motoxxx211?feature=mhee[/size]
