Well it's official, the lights in my car now dim to the beat of my subwoofers (if they're up enough, of course). I know about the battery guides advising which battery is best for the amount of power you're running, but my question is a bit different. Would my dim problem be solved with just an upgraded battery under the hood or would it be smart to get one under the hood, and a secondary one in the back? I'd rather not put an extra one in the back right now, but I will if it comes down to it.
I like the oldschool one..
Current System: Stock 2011 Tahoe
Loud as F**K
Just kidding
Do a big 3 first. Depending on how much current you are drawing, the Big 3 will help but will not diminish the problem. Personally I would do the big 3, if the drop is still a good bit, upgrade the battery under hood and a HO alternator. Doing just the battery will help but maybe not as much as you wish. The only way to get "rid" of voltage drop is a solid electrical system. If your like me and don't have much money because of university or whatever, developing a solid charging system is hard. It takes time and money. For now all I got done is Big 3 but Im still getting mad voltage drop. Therefore, I had to turn down gains until I can afford the HO alternator and battery(ies). I would rather turn down gains and listen to my system a bit lower then risk dropping below 12.5v possibly zomping out my amps. If you want to leave the gains up a bit you can rev up to say around 1500 - 1800 RPMS and that will help keep a steady voltage. That is what I had to do until I just said fuck it and turned down my gains haha. Sorry about the novel.
2006 Mitsubishi Lancer Ralliart
Alpine CDA-117
2 12" Fi Audio SSD D1
Rockford Fosgate T1000-1BD (1340RMS @ 1 ohm)
Vibe Audio LiteBox Stereo 4
Energy ENC650CV2 Component/Convertible Speakers
Knu Koncept 0 Gauge
yea big 3 and a cap can also help
Had an estimate of 6400 for an alpine/clarion setup dealer said it "should" hit around 160db with the custom boxes he was going to make for me..doubtful with so much area to move but, budget is way below that :( any ideas on cheaper brands for that kind of Spl setup? really didnt want to try any Boss or soundstorm, thinking Quantum figure around $150 per speaker "$1800 total" and $1700 to power it, first actual big setup for the van.
New MEMPHIS CAR AUDIO build
4 15s Memphis C3
2 xs power D3100
1 xs power d3400
custom fiberglass door pannel
and lots more
My Build
or i can recome the biggest battery that can fir in ur hood from xs power batteries they have the best batteries and ill hurry to ge them not shure if the price went up already
4 15s Memphis C3
2 xs power D3100
1 xs power d3400
and lots more
My Build
Big 3, got it.
I don't know what my voltage measurement is however I do have a stinger voltage meter coming in the mail so I'll definitely have a better look at what is going on with my electrical system. I'll definitely look into the big 3 a bit more and start ordering the parts I need. I have also been looking into alternators, but like you, I'm not made of money so I don't really want to dish out $600 on top of everything else I'm buying. As for revving the engine up, the dimming is still fairly noticeable so a HO alt would probably be best.
Loud as F**K
Just kidding
Big 3, got it.
If you have a multimeter or a separate voltmeter, you can check your voltage drop now. If you don't, you will need one to setup the Stinger voltmeter. For you where your running a digital amp that makes 1200w, you should be good with the Big 3 for now. Just to get you by. But, like I said, a good charging system is a must if your running any sort of aftermarket accessories.
Alpine CDA-117
Knu Koncept 0 Gauge
