Hey guys i have a problem hard to explain but here i go. OK i have an s10 ext cab and i have now two jl w7 13s just put them in but i had 1 jl 13 in it before on a jl 500/1 with 4 gauge wire a kenwood exclon head unit and a vented box build to jl specks and it played good for a while i bought it brand new and then the amp started to cut the bass by like half like i turned turned the bass down or somethin but i didnt. i thought it might be a power problem so i got a new yellow top and it still did it but the volt gauge never moved down like at all, but sometime it does move and when it does it never cuts the power out it will keep playin at the same level like normal but thats usually on warm days, but the thermal light never comes on and it never shuts off completely. so anyways i put a jl 1000/1 on it and i never had that problem like at all it works awsome and the volt gauge moves with this one and still no cut out. so thin i put a nother w7 in it and another 1000/1 and a upgraded alt and still no prob it just with the 500/1.
Now i have it on a 13 w7 in my car and its not loud at all i mean it was still really loud in the truck when it worked good like really loud but in the car it just sounds like some 10s i mean it might be cause the seat dont fold down but idk. but i had a special box built for it and im running 0 gauge to 4 gauge and brand new rca cables and all that junk and it all hooked up right well i hope lol but still dont should like a w7 should tho. but another think that's diff is im runnin a sony head unit but it has sw outputs. but if anybody has any idea on whats goin on please help me out...
A sub in a single cab will sound a lot different from the same setup in a trunked car with the seats up man.
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
If the amp is cutting out there's something wrong with the amp. And your sub probably isn't loud because the seats dont fold down.
yeah thats what i was thinkin cuz im not gettin any air flow to the cab but idk what would be wrong with the amp like i said i baught it new from and car audio shop from around where i live about a year and a half ago.. hummm
When you wired up the 2nd W7 to the 500/1 what was your ohm load at? You may have dropped low and caused some damage.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
well i never hooked up two w7s to the 500/1 i waited till i got the 2 jl 1000/1s to do that so i knew i had enough power but im usin the same 500/1 i used in the truck in the car now with a diff w7..
I'm pretty sure it went:
1) 1w7 - 500
2) 1w7 - 500, yellow top
3) 1w7 - 1000, yellow top
4) 1w7 - 1000, 2w7 - 1000, yellow top, alt
At least that's what i'm getting. He never ran the pair of w7's on the 500/1.
Out of curiosity, and on shop price, how much did you pay for each 13w7?
LOL, what's the gain at? What do you mean turn down the bass?
