Digital Designs C3b left - AND ANOTHER PRICE DROP 2/23
First off, references:
SMD Feedback
CarAudio.com Feedback
iTrader Feedback on CACO
First up are some brand new, never used sub knobs. The one on the far left is the older Rockford sub knob, a PPB1, that can be used with any of the silver Rockford Power amps.Price on it is $25 shipped.The other two are brand new AudioQue sub knobs that I'll let go for $16 each shipped.
Brand new, never installed, never opened Digital Designs C3b amplifier.It is still in the original box and taped up in the wrapping, as you can see in the second to last picture.Asking $300 $280 $270 $250 shipped.
Specs are wayyyy under-rated, as is all of DDs stuff.
Input Sensitivity 0.2V - 6V
Variable High Pass Filter 30Hz - 1.2KHz
Variable Low Pass Filter 30Hz - 500Hz
Variable Sub-sonic Filter 24dB/Oct 10Hz - 100Hz
Variable Bass Boost 0-12dB @ 40Hz
Tested Voltage 14.4
Damping Factor >100
Signal to Noise >100dB
Cont Power at 4 ohm 200W x 2ch
Cont Power at 2 ohm 300W x 2ch
Bridged 600W x 1ch
Dynamic Power 1200w
Efficiency thru Output 65%
Dimensions - mm 244.5W x 54.3H x 420L
Dimensions - inches 16.54L x 9.63W x 2.14H
Shipping Weight 13 lbs
DD C Class Amps
how much to get the recone done by FI?
Vehicle: 2017 Chevrolet Silverado High Country
Electrical: 320A Singer Alt, (2) Limitless Lithium 15ah, Full Throttle FT680-48
Speakers: Stevens Audio SA 6 (ACTIVE), Audio Designs 3”
Subwoofer: (4) B2 Audio XM 8’s
Amplifiers: (2) B2 Audio Rage 2500.1, (1) B2 Audio Rage 1200.6
Processors: NavTv M650 (integration), Helix DSP Pro MK2
Silverado Build Log
I've talked to quite a few reputable members on here that have quoted me between $100 and $140 to do it.As far as for Fi to do it, I'm not sure.I've always heard they charge an arm and a leg for the same exact thing people here do for much less so I never even bothered.
im interested in the btl. i sent u a pm on the other forum..
nvrmind, u sold it already.
Thanks for the interest but it already sold man.
