To order a re-cone e-mail [email protected] -- do not e-mail my "sundownz" address if you need a quick response.To reduce back-and-forth e-mails ALWAYS include the following :
1) What you are ordering -- Model, Coil Configuration, Etc.
2) If you already have a basket or not; please check below for any special notes.
3) If you need ANY custom options please specify up front.
4) !!! YOUR ADDRESS AND NAME !!!
5) A picture of what you have goes a long way to be SURE we are talking about the same thing.
IT WILL TAKE, ON AVERAGE, 10-14 days for a built item like a drop-in to be completed.
EDIT 8/30/11 : WE CANNOT WARRANTY DIY RE-CONE ASSEMBLY ISSUES. Read and understand this -- if you are not 110% sure about re-coning the driver ask us or send it in. We can ONLY stand behind labor that we perform. Manufacturing defects in the kit itself are of course our responsibility but installation is 100% the customer responsibility. This includes ticking, broken parts, etc. Thanks for the understanding.
This thread over-rides any prior quotes or costs -- I sat down and really calculated the numbers this morning and costs may have varied in the past on estimates.
These prices are the same for everyone; Team, dealer, customer, etc.
All costs + SH charges.
KITS DO NOT include shims or glue. White paper trimmed / stacked to spec works perfectly for shimming -- use enough where it is snug but not so tight you can barely get the coil in the gap.
For glue we suggest Loc-Tite 5-minute epoxy with mixing tubesto glue the spider to the frame (MAKE SURE to sand it first) and we suggest Amazing Goop or E6000 for the surround and dust cap (sand frame for surround and rough up the glue surface of the dust cap with sand paper as well). These can be purchased from Lowes or Home Depot very commonly and some Wal-Mart and Craft Stores. We can sell CA glue by request but it typically is not very cost effective for the end user.
MODEL -- RE-CONE Price -- FRAME Price
E8 v.2 (or v.1) -- $28.00 -- $5.00
* D2 / D4 available Stock
* MUST buy basket to re-cone a v.1 model
E8 v.3 -- $30.00 -- $5.00
* D2 / D4 Available
E-10 -- $35 -- $10
E-12 -- $35 -- $10
E-15 -- $45 -- $10
* D2 / D4 Available
!!!FOR SA-8 KITS SEE THIS THREAD TO DETERMINE WHAT MODEL YOU HAVE. WE MUST HAVE THIS INFO TO MAKE THE CORRECT KIT!!!
SA-8 v.1 or v1.5 -- $32.00 -- $10.00
* MUST SPECIFY v.1 or v1.5 when ordering !!!
* CCAW 4-layer D2 or D4 SPL Coils Available No Extra Charge (these are lighter but can still be used daily as the gap is not tighter than stock)
* These kits now ship standard with a round lead wire that is more rugged
SA-8 v.2 -- $50.00 -- $15.00
* SA-8 v.2 Kits Available with SPL 8-layer D1 Coil for $20.00 Extra (Very tight gap and may tick slightly at high excursion)
* Extra Spiders Available for $5.00 Extra Each for a MAX of FIVE (stock is two); DO NOT order extra spiders for anything but SPL
SD-2 8 -- $40.00 -- $15.00
* D4 Coils ONLY
SD-2 10 -- $35.00 -- $15.00
SD-2 12 -- $35.00 -- $18.00
* D2 / D4 available
SA-10 -- $40.00 -- $15.00
SA-12 -- $40.00 -- $18.00
SA-15 -- $50.00 -- $21.00
* SA-10/12/15 add $20.00 for SPL Coils (D1,D2,D4)
* D2 / D4 available in stock opper
NSv1 12 -- $100.00 -- $25.00
NSv1 15 -- $110.00 -- $30.00
NSv1 18 -- $120.00 -- $40.00
* 3H Nightshade Spiders Stock
* Add $10.00 for double leads
* Z v.3 Spider Available No Extra Charge
* NS v.3 Spider Pack Add $10
* D1 / D2 Available
NSv2 12 -- $130.00 -- $25.00
NSv2 15 -- $140.00 -- $30.00
NSv2 18 -- $150.00 -- $40.00
* D1 / D2 Available (SPL COIL Available)
Zv2 12 -- $100.00 -- $25.00
Zv2 15 -- $110.00 -- $30.00
Zv2 18 -- $120.00 -- $40.00
* Copper or Aluminum Coils Available
* Z v.3 Spider Pack Now Standard (5/1/12)
* MUST USE Z v.3 SPACER
* Add $10 for NS v.3 Spider Pack
* D1 / D2 Available
Z v.3 10" -- $115.00 -- $20.00
Z v.3 12" -- $115.00 -- $25.00
Z v.3 15" -- $125.00 -- $30.00
Z v.3 18" -- $135.00 -- $40.00
* Add $10 for NS v.3 Spider Pack or "Traditional" 3H NS Pack
* The 10/12 models use a different coil than the 15/18 models
* The SPL coil can ONLY be used on the 10/12 with the "Traditional" 3H NS Pack
!!!! IMPORTANT NOTE : YOU MUST USE OUR NEWEST 12-spoke 15" FRAMES TO USE THE Z v.3 OR NS v.3 SPIDER PACKS !!!! They are 8 3/8" spiders and require a modified top landing. The other spiders for 10/12 and the 18 are compatible with any 12-spoke / 6-spoke that I am aware of.
Also -- the NS cone will NOT be offered on ANY drivers with a v.3 style spider pack in 15s or 18s. The v.3 spiders (Z v.3 and NS v.3) can exceed the mechanical limits of the NS style cones in these sizes.
NEW PLATFORM PRODUCTS (Basket Prices are WITH the purchase of a SUNDOWN product re-cone) :
X-10 -- $130.00 -- $70.00
X-12 -- $135.00 -- $80.00
X-15 -- $140.00 -- $95.00
X-18 -- $155.00 -- $40.00
* 18" Use the Standard 6-Spoke Frame w/ a 257mm Spider Adapter
* D2 and D4 Coils Available (CCAW Round Wire)
* Add $10.00 for Z v.4 Stiffness Spider
* Add $20.00 for NS v.3 Stiffness Spider
Z v.4 10 -- $150.00 -- $70.00
Z v.4 12 -- $155.00 -- $80.00
Z v.4 15 -- $160.00 -- $95.00
Z v.4 18 -- $175.00 -- $40.00
* D1 and D2 Coils Available
* Softer X Spider Available - NO EXTRA CHARGE
* Add $10.00 for NS v.3 Stiffness Spider
NS v.3 10 -- TBA
NS v.3 12 -- TBA
NS v.3 15 -- TBA
NS v.3 18 -- TBA
* -- Both the X and Z v.4 kits / Frames can be retrofit into the NS v.1, NS v.2, and Z v.3 motors; these motors cannot handle the FULL capacity of the new soft parts so a hard bottom is possible.
** -- SPL kits are in development with a different cone and spider type. Pricing is TBA on those.
*** -- The Z v.2 motor bolt pattern is compatible with the new platforms as well but we do not suggest it as it has a limited amount of rearward travel (41mm).
Baskets WITHOUT a Re-Cone Kit (With Gasket and Terminals) :
10" -- $90
12" -- $100
15" -- $115
+ SH
* The new baskets are BOLT PATTERN compatible with any of our 3" coil motors to-date. They use the standard 127mm pattern so can be used on MANY other products.
Edited by sundownz
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
Glue included or not?
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
is it possible to just get a new surround for the SA subs? My friend just had a mishap and ripped his pretty bad.
It is not -- we don't have the surround separate from the cones.
How much extra would it be to have an sa-12 recone'd by sundown? Ive never recone'd a sub :drink40:
Rebuild in progress...
:ban2:
??? Or is it that easy to recone?
This topic is now closed to further replies.
