whats the outside of the car look like?
(2007 Chevy Tahoe LT)
Mechman 320A
OEM AGM
D'Amore Engineering HLC-2 Sig Converter
D'Amore Engineering E1500.1
Fi Audio Neo 3.5 12"
got my self loads of knukonceptz gear, thanks again to am at bladeice
i got loads of good stuff here is a list
2m of 4AWG BLK
3m of 0AWG BLK
1m of 0AWG RED
4x 0AWG Ring terminals
20m of 10AWG speaker wire
5m of 12AWG speaker wire
1x 2 way fuse block
1x distro block
6m long 4 channel rca cable
3m of blue 8AWG and 3m of silver 8AWG
all i need now is 2 sets of component speakers and a amp and iv got all the stuff to get it wired in straight away
and is for the bass
iv got a 180amp alternator coming and it will be at my for monday, its brand new and from grove autos
here are some pics of the knukonceptz gear
Great, you got yourself a SMD buildlog now!
See ya on TA :drinks:
______Some people and performances are beyond words______
Chairman of the foundation "Propper-Droppers Holland" 2012
Founder of the European delegation of `Propper-Droppers' 2011
Dutch Champion EMMA SQ MultiMedia advanced 2010
European Champion EMMA SQ experienced 5 channel 2007
Dutch Champion EMMA SQ experienced 5 channel 2007
BeNeLux vice Champion dB-drag street-A 2007
Dutch vice Champion dB-drag ministreet-sedan 2004
_________________________________________
Propper Droppers is about deep, ground wobbling, elephant-and-whale stimulating Street Bass.
The deep stuff. We test at different frequencies from deep, to low to snake’s belly. (Like 20Hz anyone?)
i brought and fitted a brand new 180 amp alternator (bosch)
here are some pics
it now does not drop below 14v when booming full blast and it sound louder to the ear i think aswell
now to fit the other amp
got the other amp on
it sound louder so thats good, got some box work planned which ill be doing this week
any way here is a bit of the second amp on going to tidy the wires up later as well
also i got a vid of it flexing my rubbish phone cant see it all but gives you a rough idea
all comments welcome
  • 2 months later...
i been very busy and here is a huge update
i sound deadend the rear door even more then did look like this
i removed the metal speaker frame which then i could removed the foam behind it
remove this
which then you remove foam
the finshed results
i then moved on to box work
i used 2 litres of resin in the whole of the box, put fiberglass paste in all the corners and along the sides and put a nice curve in at the bottom of the port
