4th order idea
mbdblue
2 12s in a 4th order is what Im after. I have a little space to play with, and I can't get it above the window line which is a good thing. :drink40: looking at 3 chambers; 2 sealed, middle ported. I was thinking 1.5 cubes X2 for sealed sides and 2.5-3.0 cubes for ported middle; so around 5.5-6.0 cubes total without displacement). port tuning will probably be around 50 hz. what you guys think? I really have no experience with 4th orders so this will be more or less trial and error.
Ive seen too many ported boxes and its time for me to go out on a limb and try this out, so any constructive criticism is appreciated. :clapping:
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Should work ok.
Do 45 - 60 square inches of port
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
1.5 seems little big for 12s ...i used 1.5 sealed for my 15s and ended up having to shrink em a little
i usualy use .75-1.25 cube per 12 myself (usually closer to 1")
go with a 2.5/1 ratio tuned to 47sh hz
so example
1 cube sealed x 2
so
2 X 2.5 =5 +2 -7
so youd need 7 cubes before displacement
or you could do a 2/1 ratio to save some space
R.I.P!
(Nov-29-2009)
92 explorer
current build
Im looking to do one too with 2 12's i was thinking 1-1.25 sealed per and a total of 5-6 ported tuned to 36hz
Johns.jpgSuburban Coming Soon
36hz eh haha thats going be tuned looooooow
R.I.P!
(Nov-29-2009)
92 explorer
current build
Holy lows!!
Edit:
Anyone wondering about 4th orders. A bigger sealed chamber makes the box more efficient, a smaller sealed chamber helps handle more power.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
HEHE my last blowthru held a cup at 23hz :)
Holy lows!!
Edit:
yes sir i like lows and i want it be very efficent but i do plan on throwing more power to them then rated so im torn
so example
1 cube sealed x 2
so
2 X 2.5 =5 +2 -7
could you expand on that equation a little? 1 cube per sealed, so thats 2 cubes and the center box is 2.5 cubes? how did you get 7 cubes?
thanks alot for the feedback. Im kinda goin in blind :pardon:
oh and I found a good amount of info on this link:
link to 4th order info
looking at each sub sealed chamber being 15 x 16 x 14 @ 1" thick MDF leaves me with 1.26 cubes (with the displacement of sub and 45s should be damn close to 1 cube)
and the ported chamber being 30 x 16 x 16 @ 1" thick leaves 3.18 cubes.
looks like the subs will be inside facing forward and the ported chamber in front of them also facing forward. pretty much like this but will be one port and 2 12s. any downsides for this positioning? :pardon:
so example
1 cube sealed x 2
so
2 X 2.5 =5 +2 -7
you have your sealed partition which is 2 cubes total (for both subs 1 cube each sub) then you got your ported partition which is 2.5 cubes per 1 cube sealed
so think of it as 2 box's your back box which is your sealed box (2 cubes) and your ported box which is 5 cubes so you would add those 2 up and your left with 7 cubes
like so
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 852 Guests (See full list)
