vettetruck Posted February 26, 2011 Report Posted February 26, 2011 I recently got 2, 15 inch Orion XTRPRO's ( new 1000 watt 4 ohm model ) and a 2000 watt amp. My question is, what are my optimal amp settings as far as subsonic filter, low pass and so forth to get the best low frequency response? I don't expect to bump the lows like Steve can but you know what I mean. Oh, btw way they are in a channeled box in spec with Orion's recommendation. Any and all advice would be greatly appreciated, thanks!
kickass audio Posted February 26, 2011 Report Posted February 26, 2011 first of all.. what is your box tuned to (if it is ported) Second, the subsonic filter is used to stop your sub from playing frequencies that are wayyy below its port tuning. For example, if you have a box tuned to 30Hz, you want to set your subsonic filter to 28Hz. If you dont use the subsonic filter just right you can bottom out your sub and start going through subs like i have (trust me, i go through subs like crazy because i was stupid with my setups) The low pass setting on your amp is used to tell the amp what frequencies it should allow to go to the sub. Most people recommend setting it to 80Hz because at that setting, frequencies from 80Hz and below will go to the sub. And if you are using a amp for your door speakers you should set the High pass freq (HPF) to 80Hz so that frequencies from 80Hz and above will go to the door speakers. the last thing you want to have is to get a bass note to hit your door speakers and have a full range setting for your subs. it will sound like crap if it does. Also if you dont have one yourself or know a buddy who has one, get a o-scope to set your gains properly. No matter what you may find on the internet (or even here for that matter) you can NEVER truly set your gains with a DMM (digital multi-meter) it just isnt accurate. I proved this to myself by using a chart that was online that said for a specific RMS rating of the amp and at a specific ohm load you should have XXX of voltage coming out from your speaker terminals. Well turns out that when i did that and hooked up my new o-scope to it, it had a clipped signal. And if i were you, DO NOT use bass boost at all unless you have an o-scope to tell how far you can turn that up along with your gains to get a clean signal. clipping a speaker is very bad to do. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
vettetruck Posted February 27, 2011 Author Report Posted February 27, 2011 first of all.. what is your box tuned to (if it is ported) Second, the subsonic filter is used to stop your sub from playing frequencies that are wayyy below its port tuning. For example, if you have a box tuned to 30Hz, you want to set your subsonic filter to 28Hz. If you dont use the subsonic filter just right you can bottom out your sub and start going through subs like i have (trust me, i go through subs like crazy because i was stupid with my setups) The low pass setting on your amp is used to tell the amp what frequencies it should allow to go to the sub. Most people recommend setting it to 80Hz because at that setting, frequencies from 80Hz and below will go to the sub. And if you are using a amp for your door speakers you should set the High pass freq (HPF) to 80Hz so that frequencies from 80Hz and above will go to the door speakers. the last thing you want to have is to get a bass note to hit your door speakers and have a full range setting for your subs. it will sound like crap if it does. Also if you dont have one yourself or know a buddy who has one, get a o-scope to set your gains properly. No matter what you may find on the internet (or even here for that matter) you can NEVER truly set your gains with a DMM (digital multi-meter) it just isnt accurate. I proved this to myself by using a chart that was online that said for a specific RMS rating of the amp and at a specific ohm load you should have XXX of voltage coming out from your speaker terminals. Well turns out that when i did that and hooked up my new o-scope to it, it had a clipped signal. And if i were you, DO NOT use bass boost at all unless you have an o-scope to tell how far you can turn that up along with your gains to get a clean signal. clipping a speaker is very bad to do.
vettetruck Posted February 27, 2011 Author Report Posted February 27, 2011 first of all.. what is your box tuned to (if it is ported) Second, the subsonic filter is used to stop your sub from playing frequencies that are wayyy below its port tuning. For example, if you have a box tuned to 30Hz, you want to set your subsonic filter to 28Hz. If you dont use the subsonic filter just right you can bottom out your sub and start going through subs like i have (trust me, i go through subs like crazy because i was stupid with my setups) The low pass setting on your amp is used to tell the amp what frequencies it should allow to go to the sub. Most people recommend setting it to 80Hz because at that setting, frequencies from 80Hz and below will go to the sub. And if you are using a amp for your door speakers you should set the High pass freq (HPF) to 80Hz so that frequencies from 80Hz and above will go to the door speakers. the last thing you want to have is to get a bass note to hit your door speakers and have a full range setting for your subs. it will sound like crap if it does. Also if you dont have one yourself or know a buddy who has one, get a o-scope to set your gains properly. No matter what you may find on the internet (or even here for that matter) you can NEVER truly set your gains with a DMM (digital multi-meter) it just isnt accurate. I proved this to myself by using a chart that was online that said for a specific RMS rating of the amp and at a specific ohm load you should have XXX of voltage coming out from your speaker terminals. Well turns out that when i did that and hooked up my new o-scope to it, it had a clipped signal. And if i were you, DO NOT use bass boost at all unless you have an o-scope to tell how far you can turn that up along with your gains to get a clean signal. clipping a speaker is very bad to do. Thanks for being so thorough man. I got all the info about the tuning, the only thing im not sure of his how to know what my box is tuned to (<<< rookie ). Yes it is ported.
00mgm Posted February 27, 2011 Report Posted February 27, 2011 You can get the dimensions of your box then the dimensions of your port and plug those into the torres calc and have a pretty decent idea. 2000 Grand Marquis Digital Designs 9512 Rockford T2000bd1
kickass audio Posted February 27, 2011 Report Posted February 27, 2011 youre welcome dude. i was once a noob as well, hell we all on here were noobs at one point or another. For your box tuning see if you can do this for me. get me the dimensions of your box. Height: Depth: Width: Wood thickness: also get me the port dimensions: Width within the port: Height within the port: Length of the port: There is a program on here called torres calculator that i use and it does a damn good job at telling you how to build/tune a box. in fact im using it as we speak to design my box im making this spring/summer for my single Ascendant Audio SMD 18" woofer. If you can give me the information i asked for above i can instantly get you the tuning frequency of your box in a second. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
vettetruck Posted February 27, 2011 Author Report Posted February 27, 2011 Ok bro I'll get it in the morning. LOooonnggg day on the job. Appreciate the help once again. Are those subs capable of cranking out 30hz?
kickass audio Posted February 27, 2011 Report Posted February 27, 2011 that i do not see a problem with them handling 30Hz but like i said see what your box is tuned to first of all. the box tuning is going to make a HUGE difference with your sound. if its off tune you will have shitty sound and if you play a note lower than the box's tuning you can bottom out the sub and do what i did with my subs and bottom them out and burn the coils and all that bad stuff. but the subs have a rating of 20Hz-2.5KHz for response so yes 30 should work just fine but i havent EVER used orion products so i cant speak off experience unfortunately. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
vettetruck Posted February 27, 2011 Author Report Posted February 27, 2011 that i do not see a problem with them handling 30Hz but like i said see what your box is tuned to first of all. the box tuning is going to make a HUGE difference with your sound. if its off tune you will have shitty sound and if you play a note lower than the box's tuning you can bottom out the sub and do what i did with my subs and bottom them out and burn the coils and all that bad stuff. but the subs have a rating of 20Hz-2.5KHz for response so yes 30 should work just fine but i havent EVER used orion products so i cant speak off experience unfortunately. Ok, here's what I got: 17 in. from front to back ( measured on top ) 16 in. tall (measured from front ) 39 in. from left to right ( measured on top ) 1 in. on wood thickness as far as the port dimensions go, each 15 has its own channeled port with the following dimensions: 16 in. deep ( stuck the tape measurer into the port until i reached the back wall ) both sides 1.5 in wide for each port opening at the front of the box 14 in. tall for each port box front looks like this , the " ||| " being the the channeled ports: __________ | O ||| O | ```````` So hopefully that will give you an idea what im working with. Thanks bro.
kickass audio Posted February 27, 2011 Report Posted February 27, 2011 ok, i just plugged the numbers into the torres calculator that is on here and i came up with a 40.65Hz frequency tuning per sub. so you should look at a 35-40Hz subsonic filter. Normally you would only go 2Hz less than your port tuning and NOTHING more than that because you can bottom out the subs and burn/blow the coils. If you havent already id recommend turning OFF any bassboost you may have on and for setting the gains on your amp make sure your headunit's EQ is set to FLAT. if you do not have it set to flat it will really screw it up when you try to tune the amp with the dmm later on. Unless you have an oscope i really dont recommend messing with any bass-boost or loudness equalization because they always cause a lot of clipping on your signal which in turn destroys your subs/speakers. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
