Mechman Alternators
what car? and do you have the big 3 done? and most importantly how good are your grounds? with a 300amp i would think youre looking at over 15v at idle, my dc 270 idles at 15.4 15.3 warmed up but as soon as i gas to 1k rpm goes back to 15.4
depending on the year of the car maybe the computer wont process it,
so here is a few things you could try
1* go toautozone get a load test(could be a bad alt, a company wont have perfect luck with every single alternator they make)
2* get a multi meter and stick it on the battery with the vehicle running
but like i said only thing i would guess is bad grounds because that is waaay too low
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
From the but I have learned the setting depends on type of batteries your using like AGM or what. I'm still learning on mine also, your going to have to set it around 14.9v at 1000rpm at start up that way when it warms up the voltage will drop down a bit but should stay in lower 14v range if using AGM batteries.
To some this seems so easy but I know me and you as well all the new mechman adjustable voltage boost module owners are in need of help on this topic.
Are you saying it drops to 12.5 under load or this is just under normal operation. Meaning you stop at a light (no stereo) and it does it or is this under a load?
As far as wiring goes (all 1/0, this isn't optional). Alt to ground (frame or strut tower if unibody), ground to batt. Alt power to batt.
On a related note, if you have that many batteries you really should get a charger.
Edited by UnderLoK
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
I told him he needs to top off his batteries to start.
He's got a Stetsom 11k with 6 blue tops and idk what battery in the front. Batteries have got to be drained from all the sampo's you've given ryan lmao. Throw them bitches on a charger and once they're topped off THEN check your voltage. If it's still low, do your whole big 3 cheapass XD
I run a mechman 250amp alt and mine does the same thing as the op. I have everything set up with big three and xspower batts. I idle very low too especially when the vehicle is warm.. sometimes down below 500 rpm. I dont think anything is wrong with the alt at all.
  • Who's Online   0 Members, 0 Anonymous, 718 Guests (See full list)
