bigp_on_the_beat Posted February 28, 2011 Report Posted February 28, 2011 What up SMD bass heads! So my friend wired his own system and got lazy, not hiding wires or anything like that he just wanted it working, his amp is 5 inches away from his box but he used about 10ft of speaker wire from sub to amp. My question is: does having all that wire affect the bass? When he plays a song it seems like the bass hits late like it stalls, does having too much wire do that or is something hooked up wrong? or why wouldn't be stalling? System: Pioneer head unit 2 kicker cvr Alpine mrp-1000 amp All the help is greatly appreciated. No car at the moment. New system: 2 Skar Audio VVX-12s Crescendo bc2000d Carquest NGT battery (back) Deka battery (front)
ChevyBoy95 Posted February 28, 2011 Report Posted February 28, 2011 it shouldn't, and the amount of resistance of that wire(10ft) compared to a 3 ft piece is negligible. And the length of wire shouldn't cause the timing of the bass to be off either. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
AA98hoe Posted February 28, 2011 Report Posted February 28, 2011 sounds like an enclosure issue maybe TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
MrSkippyJ Posted February 28, 2011 Report Posted February 28, 2011 it can, but in your case (or your friends case) it isn't. It would take LOTS of wire to have the effect you are describing. Try switching the polarity on your subs and see if that helps. OR change the phase switch if you sub amp(s) have it. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
bigp_on_the_beat Posted February 28, 2011 Author Report Posted February 28, 2011 it shouldn't, and the amount of resistance of that wire(10ft) compared to a 3 ft piece is negligible. And the length of wire shouldn't cause the timing of the bass to be off either. Thanks, maybe he just wired something wrong I'm gonna have to rewire everything then No car at the moment. New system: 2 Skar Audio VVX-12s Crescendo bc2000d Carquest NGT battery (back) Deka battery (front)
bigp_on_the_beat Posted February 28, 2011 Author Report Posted February 28, 2011 it can, but in your case (or your friends case) it isn't. It would take LOTS of wire to have the effect you are describing. Try switching the polarity on your subs and see if that helps. OR change the phase switch if you sub amp(s) have it. I'll test the phase right now and check if he wired something wrong No car at the moment. New system: 2 Skar Audio VVX-12s Crescendo bc2000d Carquest NGT battery (back) Deka battery (front)
MrSoHeavySPL Posted February 28, 2011 Report Posted February 28, 2011 make sure the speaker wire is the same length too 96 GRAND MARQUIS 2 Kole Kmx 15s 6.0 A.E. box tuned to 42Hz 1/0g power and ground Huge Duralast batt. Stock 130a alt Amplifier - Dual XiA2460(hardcore p.o.s.) Head Unit- Kenwood KDC-X693 AudioControl Three.1 Audiobahn bass line driver Teh Big 3 in Kollosus Fleks 1/0 Funny Youtube Shit MATUXAZ 2 weeks ago "In wikipedia i found that this sub in 1997's unofficial private SPLdB drag was burned down the dB meter! The dB was over 300 and the system burned down. Actually, 300dB is only about ¼ of this prototype sound level." I don't know anything about guns... so when I saw the title I thought, "I wonder what kind of woofer the AR-15 is?" *laughs* Twisted, I would stay away from that guy, the next video he uploads could be you tied up in his living room while being forced to watch him "swag and cook" in person, lol.
bigp_on_the_beat Posted March 4, 2011 Author Report Posted March 4, 2011 it can, but in your case (or your friends case) it isn't. It would take LOTS of wire to have the effect you are describing. Try switching the polarity on your subs and see if that helps. OR change the phase switch if you sub amp(s) have it. Thanks for the info it actually was the phase it was turned up 80% when I turned it down it wasn't lagging anymore No car at the moment. New system: 2 Skar Audio VVX-12s Crescendo bc2000d Carquest NGT battery (back) Deka battery (front)
white4d96 Posted March 4, 2011 Report Posted March 4, 2011 Mine lags regardless of phase, i think it's just crappy box, not enough port? Too many projects, too little time...
