Go-N-Def Posted February 28, 2011 Report Posted February 28, 2011 Id like to know what would happen by running an amp that 2 ohm stable down to 1 ohm or .50, And a 1 ohm stable amp down to .50 or .25 Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
R3nOSlaPP Posted February 28, 2011 Report Posted February 28, 2011 most low end amps pioneer or boss would blow at .25 ohm but amps such as an audioque or dc say 1 ohm stable but you can run it at half an ohm all day an be fine just gotta have clean power low ohms put alot of stress on electrical throughout the vehicle so if you havent upgraded your electrical dont try Vehicle: 2017 Chevrolet Silverado High Country Electrical: 320A Singer Alt, (2) Limitless Lithium 15ah, Full Throttle FT680-48 Speakers: Stevens Audio SA 6 (ACTIVE), Audio Designs 3” Subwoofer: (4) B2 Audio XM 8’s Amplifiers: (2) B2 Audio Rage 2500.1, (1) B2 Audio Rage 1200.6 Processors: NavTv M650 (integration), Helix DSP Pro MK2 Silverado Build Log
Go-N-Def Posted February 28, 2011 Author Report Posted February 28, 2011 My prob is I like Crossfire but its 2 ohm stable cant do a lot with it with underground subs like Fi with 2ohm or 1ohm coils. Im not sure if anyone should run to low passed 2 ohms. i feel i might have to let go and turn to AQ. The mainstream and seams useless now unless you have mainstream subs like 4 ohms svc and dvc. Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
n8ball2013 Posted February 28, 2011 Report Posted February 28, 2011 buy subs or buy amps thjat work for your configuration. running lower than rated can and most likely will result in a smoke show. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Go-N-Def Posted February 28, 2011 Author Report Posted February 28, 2011 buy subs or buy amps thjat work for your configuration. running lower than rated can and most likely will result in a smoke show. Prob should match amp and sub as close as i can. thanks. Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
