13.7volts...I need help!!!
Ok so ive done the big 3...i have a 3yr old battery that will get replaced with a yellow top soon... But my question is would it be smarter to get the 120amp alt first(i think i have a stock 90amp) or get the new optima yellow top? and would my voltage get up and over 14v?? Thanks for the help guys...
what vehicle? could be the alt's set point to charge that high. Replace the battery then get the alt. 13.7 really isn't a big deal.
Johns.jpgSuburban Coming Soon
Its a 96 Dodge Ram...when the truck is running at idle it says 13.7 and when i bring up the rpms over 2k it still says 13.7... Im just curious because my new amp is on the way and it says its 1krms at 14.4v so if i dont have the voltage i wont get my 1k rms?? or am i wrong?
Don't worry, you won't get the 1k out of the amp anyways. Between box rise, voltage drop, db levels of music, etc you are never going to see a true 1k out of your 1k amp. It's something that everybody has to deal with. Don't be so concerned about 13.7 volts, just because a lot of people here boost their voltage up to 15.1-15.3 doesn't mean anything below 14.4 is bad. Hell just staying in the 13's is still good with the system on.
I don't wanna say for sure, but I think all the newer Dodge/Chrysler vehicles have a set point in the PCM of around 13.6 volts. I didn't really know this, and was wanting the magic 14.4 as well, so I bought 2 Kinetik batts, and a 190 amp Load Boss. But the voltage is still the same, it's the amperage that was increased. If you want to increase the voltage, you will need a voltage modal, or regulator, what ever you want to call it. It allows you to adjust the voltage output from the alt, and it doesn't matter what alt you are using. They work on stock. PT Cary just told me about it a few days ago. You can find them at
www.missinglinkaudio.com
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
  • Who's Online   0 Members, 0 Anonymous, 436 Guests (See full list)
