im going to have 5 P1 12s Single 4ohm and i need some help wiring them down to 1 ohm could someone draw up a diagram or try to explain this to me cause i cant get the math right
You can wire it to .8, that is, if, you are using 1 amplifier on all 5. You will just wire them parallel, + to +, - to -.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
What kl0wn said.
Here's a pic
Just wire the 5th sub the same way
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Yeah, kl0wn has probably the best solution. If you had 4 it would be perfect.
2004 Ford Mustang GTPioneer DEH-P7200HD head unitMach 460 Factory System
Cadence FXA1600.2
Cadence S2W10
Cadence 4 AWG wiring
Ported box, 2 cubes, 32 hertz
Posted (edited)
It is your only choice unless you want 20 ohms (all in series).
You can not do any type of series/parallel with 5 single voice coils. If you do, all 5 subs are not going to get the same amount of power.
Try all 5 in parallel. If the amp won't take it, get rid of 1 sub, or get a new amp.
Edited by bkolfo4
Current system:
Previous systems:
It should go even lower your electrical better be ready for .5 ohms
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
