just cause you have new batts doesnt mean you have full voltage coming through the leads..
:drinks: there could be a problem in the switch or in the harness.
I know, my voltage on the front battery is 14.4. Not sure about at the harness.
2008 Dodge Ram 2500 6.7l Cummins
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
Audio Technix Wiring & Sound Deadener
My Youtube
Feedback
are you using a relay??? if not you need to get the relay harness and wire it in...
thats your problem :good:
mine where doing the same thing, from now on i usually use the harness either way just incase. sometimes one would work sometimes both, they would aslo flicker :(
get a harness it should take care of your problem, i would
Edited by BeatBox
Dude, it is absolutely the ballast. No doubt about it, the ballast. I've had the same problem, ordered 3 ballast that fucked up, and the 4th one worked, then my bulb went out. But, I'm gonna guess you are ordering off of ebay, and that is a serious issue with ordering from there...by the time they ship from across the country, shit breaks. Order from a reputable store that has warranties and will actually replace shit if its broken.
Edited by BakermanINC
I don't think they even sell harnesses there...
make your own.. get a relay from radio shack and wire it in..
its really easy and straight forward to do.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
HIDS still don't work... the bulb comes on but just flickers but then when I hook it up on the other side it works fine... I tried 2 different ballests(one brand new) and it still does it... if I hook up the normal headlight on that side it works fine... the HID worked fine for 3-4 months then quit working(light wouldn't come on at all) so I switched the ballest to a new one and then the light came on but flickers, so I ordered a new bulb and it came today but still does the same thing. But I can hook but the bulbs up on the other side and they work fine... any ideas?
sry thought u also meant the ballast too, did u switch the ballast to the other side?
No its from HIDExtra.com I have One more brand new ballast ill try it...
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
My Youtube
Feedback
just a question, i had this problem with my hids but this fixed it
is your power going in the ballast correct? like is pos going to pos and neg to neg cause when i had mine hooked up the pos was neg and the neg was pos and it would flicker like hell
oh, and relay kids are easy to make, just a few female spade connectors, some 10guage wire for power n ground, maby 16guage for swiched and a inline fuse holder and ur set, or u can make ur own inline fuse holder wit 2 insulated female spade connectors
its pritty str8 forward
but this is what happined to mine, try the ballast on a different side with a different bulb to take the bulb and ballast out of the equation
im running 2 35w hids off one side of the headlight harness, only relay i got is for high and low beam
edit: ddm tuning ftw cause they sell everything cheap and its good and they have great customer service :)
Edited by tacomabanga1986
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
