Hey guys, there are tons of things that i know and a lot more that i don´t , i´ve always seen people routing the edges of the box and i know for sure that you can gain some tenths on the termlab by doing this, also, it looks tight IMO hehe , anyways , my question is, how you guys do it without damaging the "razor" (english sucks hehe) of the router with the screws???? i mean, i have to screw the box together before routing the edges so that´s why i´asking!!
Maybe the only way it´s by not using screws but you use "staples" (that´s the name) instead?? thanks for the inputs :)
drive the screws deeper. or when you see a screw go over it really slow.
2006 Nissan Z Track.
My Feedback Thread
unscrew the screws.
SPL-Lab REPCar: 1996 Honda Accord F22B1 CoupeSuspension: Megan Racing Full Street Coilover Dampener KitAlternator: DC Power XP 270Batteries: XS Power D5100 & D3100Wiring: KnuKonceptz & 2/0 Welding cableHeadunit: Kenwood KDC-MP642UComponents: Hybrid Audio ClarusAmplifers: Lanzar OPTI250X4Subwoofer: 2 Sundown Audio E8.v2Deadener: Sound Deadener ShowdownSPL Meter: SPL-Lab RTA Pro meterWant an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has the same features? PM me.CA ref: (enellz, 92c1v1c, el_chupo_, Thixx, Kraudio12, SethPhillips, NJack2AF, JamesKarr, ExpoSport, 01 S 10, wgsj_fortvalley, fast306stang, Lakota, blackga, TheLow, adrian1185, the727kid, rudy, sundownz, lmllopez, traksta15, gentlejax, satchel50207, Bigthangs, Goindef154)CACO ref: (extremechevyman67, ghostmechanic, FatBoy2, TheMan007, bdufner, 350zkid, ironb, bmansbach)SSA ref as phi: ( shizzzon, porkchop, onebadmonte, stevemead, TRP, ///M5, denim)SMD ref: (DC Power Rob, Nathan@XSPOWER, Jman08)And then some.
unscrew the screws.
thaT was my first idea, but wouldn´t look like shit when i screw them again?? or maybe it would crack a little bit the MDF since it would shrink the size of it??
after your glue has dried, you don't need the screws anymore.
Deeper? that´s a good option? i mean, wouldn´t the router still reach the screw??
^^^True...this is how I do it. I get a "countersink" bit, which actually makes a hole a couple of cm deep that are just bigger than the screw head, leaving the screw below the surface of the wood. I pull them out one line of screws at a time, route my edges, then put them back in, put a little bondo over them. The bondo works if you are not covering in carpet, but painting or covering in rhino lining. Just gives it a smooth look.
No. The router bit doesn't eat away that much wood lol. And you can adjust how much you want to take off. I go over screws/nail gun nails all the time. Just go slow. You go quick it'll catch and not be good. Blade is still sharp too.
My Feedback Thread
Just take them out and then put them back in if you want.
its what i do
R.I.P!
(Nov-29-2009)
92 explorer
current build
