ok with the setup i have now im gettin a constant 12.5v but im wonderin if the 3000db will drop the voltage any.
if u think its needed would a yellow top and a 80 amp alt work (i only have 4 ga wire)
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
your gonna have to go to bigger wire, do the big 3 and possibly a bigger bat.
is your stang a V6? cause my GT had a 140 amp alt in it and I did just fine with more power than that Pa amp
Guest MegaloManiac
dude if you are getting 12.5v then you are running off the battery, upgrade asap!
ok a unanimous upgrade that makes me happy =(
ok so ima need new wire (0ga?) new battery (yellowtop?) and a new alt (100 amp or wut?)
gimme wut u got but dont expect this to happen soon
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
just figured out i lied
took my car outside had my system turned up loud and my l.e.d.s goin and i was gettin 14.5v at the cap
does that change anything?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Guest MegaloManiac
before or after cap? if its before you're fine for now; but upgrade will still be good
Edited by MegaloManiac
well that is wut the cap display says so...
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 4925 Guests (See full list)
