what could you do with 10 cubes or 30 cubes of airspace
i measured my truck and found out i can put up to 30 cubes of airspace in a box. what could i do with 10 cubes. and what can i do with 30 cubes
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
all depends on the budget my man... different subs need different airspace we could say 4 18s or 8 18s depending on price lol
Live life to the full... Then TURN THAT BITCH UP!
10 cubes won't get you far...and it depends on the setup your looking go and what subs you want to use. There's a ton of variables. Is that 30 cu feet including room for extra batteries/amps? Etc.
10 cu feet would get you roughly, after displacment, 2-3 15s, 1-2 18s depending on make, 4-5 12s, etc.
Keep in mind those are very rough guesstimates with how many variables there are. Some subs like more air, some like less.
well for either one i gotta take out my back seats. the thing i like about a 10 cube box is that i could see out of my back window. for the 30 cubes it'll be a straight up wall but i would also get more bass. 4 18,s in an extended cab truck would be nuts though. maybe a little too costly
hmm i think the 2-3 15's would be what id go with. i have to actually raise the box about 5 inches from the floor because of the the transmission tunnel so im thinking thats where i could put my amps
if it's in an ext cab chevy do a wall like AMI CUSTOMS did on here with 4 15's, he's loud and build is quite clean..go look at it
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
thanks ill go check that out
  • Who's Online   0 Members, 0 Anonymous, 1307 Guests (See full list)
