Mechman Alternators
Hmm can't seen to find something to suite me
I am not retarded but I just had a hard time finding things on your site. I have a 91' civic hatchback, everything is stock. When I get my system I am most likely going to have a 1600 watt system. So I am most likely going to get a XS battery that can support a 1500 watt system or more, but what alternator, if any you have. would best suite that because I am sure a 270 amp alternator that is $400 is a bit overkill for 1 battery.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Actually, I would recommend our 150 amp large case conversion kit for $449
The problem with a 91 Civic, is that the tiny stock alternator is not suitable for anything more than about 65 amps. Some companies will offer cheap "rewound" units in the OEM honda housing, but they will have ZERO output at idle, and will also burn up quickly due to their tiny rectifier and limited cooling.
Other companies will sell you a GM alternator with a solder-on pigtail, and expect you to figure out how to shoe-horn it into the stock bracket and make the belt line up.
We sell a complete bolt in, plug in kit, that comes with a custom machined slim fit large case late model alternator, the necessary adapter bracket, and plug-n-play harness. This is the only way to get a durable unit in that location that still has good output at idle and 100,000 mile durability. Our kit also comes standard with our adjustable voltage boost module so you can set the charging voltage to whatever you want! Our kit may be a little more expensive than what other companies sell, but you get what you pay for!!
Edited by MECHMAN
  • 3 weeks later...
I do see that is quite expesnive, but it is good money. Well since the prices are chaning up on me, I will not get this just yet but when I do get to getting this car have a system I will definatly hit you up.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Actually, I just realized that was a typo. The 150 amp kit is $449, the 220 amp kit is $549. Sorry about that, I fixed it in the post above.
  • Who's Online   1 Member, 0 Anonymous, 491 Guests (See full list)
