SPLadd1ct Posted March 10, 2011 Report Posted March 10, 2011 I am powering a Sundown 4500D amplifier. My electrical will consist of a Mechman 220A alternator, two XS D3100 battery's, one XS D2400, and a ton of Stinger 1/0 HPM wire. I was going to do 2+ and 2- runs from the front battery to the back battery. But since the firewall is a pain in the aft end I am going to have the geek squad do it, since they are liable if they mess up my car. So why not make it more hell on their part and make them do 3+ and 3- from the front battery to back battery? Is there a pretty decent benefit towards doing an extra + and - run or is it not worth the extra length used up in wire? I have 100' so I have plenty to go around. 2011 Ford Ranger Sport 4.0 v6 2 sundown audio prototype nsv4 15s crossfire 4k wired to 0.4 ohm 15 banks of maxwell 3.0 caps @ 18v triple alts (x2 us alt 250's, x1 singer 320) 153 at 23hz
fr34kout Posted March 10, 2011 Report Posted March 10, 2011 More runs is never a bad thing. With that many runs, they may end up running the wire under the car and zip-tying it up along the frame, then bringing it back into the car wherever the batteries are going to go. If they go this route, you may want to ask them to run it in a PVC pipe or something to protect the wire. Because I highly doubt they'll try to stuff 6 runs of 1/0 through the firewall. Honestly, 2 runs should be fine and I'm glad you decided to also run negative runs. 3 isn't "overkill" but you probably will only see marginal benefits.
SPLadd1ct Posted March 10, 2011 Author Report Posted March 10, 2011 More runs is never a bad thing. With that many runs, they may end up running the wire under the car and zip-tying it up along the frame, then bringing it back into the car wherever the batteries are going to go. If they go this route, you may want to ask them to run it in a PVC pipe or something to protect the wire. Because I highly doubt they'll try to stuff 6 runs of 1/0 through the firewall. Honestly, 2 runs should be fine and I'm glad you decided to also run negative runs. 3 isn't "overkill" but you probably will only see marginal benefits. Yeah I don't want to run the wire underneath the vehicle. For some reason I just like the idea of all the components being inside my nice dry car (OCD). It would be pretty entertaining trying to watch them stuff 6 runs through, I'd imagine there would be a lot of frustration involved. I believe the 2+ and 2- runs will be sufficient. I hope they will be able to stuff the 4 runs as it is through the firewall. I have the appointment March 20th so I will let you know how it goes. 2011 Ford Ranger Sport 4.0 v6 2 sundown audio prototype nsv4 15s crossfire 4k wired to 0.4 ohm 15 banks of maxwell 3.0 caps @ 18v triple alts (x2 us alt 250's, x1 singer 320) 153 at 23hz
P4killer_ Posted March 10, 2011 Report Posted March 10, 2011 if i had to put 6 runs through the firewall id cry. barely a good spot for 1 (for me neway) Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
fr34kout Posted March 10, 2011 Report Posted March 10, 2011 I have an Envoy (mid sized SUV) and I only did my 2 power runs through the firewall. My 2 ground runs which just got done recently I found a rubber grommet in the floor right in front of the driver seat. Dropped it down there and then ziptied it along the frame up to the engine bay about 4 ft. Don't be surprised if all the wire isn't run through the firewall, for most people doing 1 run is a bitch let alone 2, 4, or 6.
bumonskateboard6 Posted March 10, 2011 Report Posted March 10, 2011 If you're bringing in your own wire and asking best buy to do it then putting your amp in I really doubt they will cover or warranty any of their work for running power wire. Best bet is honestly PVC and run it under the car. It'll actually sound better too because you won't have 4-6 runs of power wire in the cabin with your speakers/speaker wire or signal cables. Just my 2c though. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
