DC LVL 6 2010 Mustang GT *TL Scores pg.73*
I'm bored with homework, so I went out and did a couple small things. First, I finally mounted my bass knob, its been sitting in the cup holder long enough lol. And yes, I drilled another hole to run the wire.
Before
Now
Then, found a place for my voltmeter. Not hooked up all the way yet. I need wire to run back to the amp. Also discovered I'm only charging at 14.1 :(
SMD Super Seller
My Feedback Thread
Hooked up the voltmeter. I'm concerned about the idle voltage. It was at 14.1 early today when the car was cool. Now that its warmed up, it sits at 13.8-13.9. Good news is it only drops to 13-13.1 full tilt with the lights, fogs, max a/c, and defroster all on.
SMD Super Seller
My Feedback Thread
i see 13.8 all the time and i dont get why
my idle voltage is 14.6
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Did you use a DMM to re-adjust the volt meter properly?
formerly known as Blue86f150
this sux camel dicks
Hm, that seems way to low for the DC alt. maybe the ford computer is just over riding it so it can go above 14.x volts. Most likely the case though.
I love the black rims. Beautiful car.
Hairtrick :pardon:
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
What?
i see peoples cars charging at 13.8 like yours. no idea why because mine charges at 14.6
what kind of extra battery power do you have? i noticed that with only a highs amp and an extra battery my voltage rested down in the low 14s. i figured that it had to do with the alt having a very minimal load on it so it wouldnt charge as much
i could be way off though. probably am
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 2193 Guests (See full list)
