94Beretta and Fi 18 build *9/10* vids/hair trick
Thanks guys! Im out of town right now so no progress.. But a little idea im going to be doing involves solar panels and charging my batts with them.. Keep an eye out for that and my doors finished
  • 3 weeks later...
Me need updates naow
I know.. Been haveing other problems and places my money is going to.. Also haveing issues with mounting my door pods.. PLUS im doing a build for my father. I should have a update any day now hopefully
One way to lower, quick and cheap, is to take the coil spring out and cut a coil, that should give you 1/2"-1" drop, would take a day if you have the tools
That wouldnt mess anything up?
It wouldnt hurt anything. If you cut the coil at the same point of where the top one stopped all your bushings and stuff will still line up. Just make sure that everything is tight and in place. I drove my SHO with the coils cut for like 3 years before selling the car. The ride was a little stiffer, but it just rode like a lowered car.
You go more than a coil it may cause issues, just dont get crazy!
Pioneer AVH480
Zapco ST5XII amplifier
Stevens Audio 6.5" components (passive)
Onyx Subwoofer
Sky High OFC wiring
Little bit of progress here, plus tinted my tail lights.
Thanks audio-concepts for help with mountin the door pods!
Heres the tail lights! There pretty dark. Im gana end up tinting the middle plastic there also because the lights ended up darker then it. Lol 07a23675.jpg
The bracket worked beautifully! Now its all about finesse with sanding!
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
I agree! Those are a little big im gana try some smaller ones and two more on the top also.
Not looking forward to the sanding at all.
If you have a palm sander, cut down surface bondo with 40/80 grit, till its more uniform, then stick with 80 grit until you have a nice flow, then run 180/320 till its smooth! Then coat with high build primer (4-5 coats), then wet sand with 600!
Any auto body supply store can mix up a single stage paint to match your interior! I think they would look better color match as opposed to wrapped in fabric.
Little more money, but looks factory!
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
Got one door panel ready to be wraped or painted whichever i choose. But i have some black suede laying around so i wana try and wrap them with that but idk if i have the talent to do that. Heres a few pictures. Im gana start the other one tomaro.
Not to horrible for my first ones!
Let me know what you think!
finish this. now. nice pods. you got some skills.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
