Voltage and RPM problem (urgent)!!!
When im driving my Tahoe or when i start it up and its parked it does the following things.
1) The Voltage goes up and down aswell as the rpms
2) Lights dim and get strtonger along with the voltage when it does this.
It does those things when im either parked or when i am stalled at a red light but as soon as i accelerate it stops doing that until i once again stop or park it.
i need help please so i can figure this out because this is borrinw the hek out of me. Help would greatly be appreciated.
(soorry if this is the wrong forum for this question)
You got a serious idle problem. Its could be a dozen things, put it on a scanner a read the codes.
Edited by dc98hoe
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Unplug the alt and see if the truck idles fine. I had this happen to me when my alt was bad. Above 1200 rpms it was fine, at idle I would bounce between 12-14.7v
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
  • Who's Online   0 Members, 0 Anonymous, 1277 Guests (See full list)
