forums r really confusing, i dont understand wat ur saying 2 wat i asked.
so in shorter words i should get a 250 amp anl fuse right?
incriminator audio death penalty 18' dual 1.6 to be exact.
hifonics brz2400.1 wired 2 .8 ohms.
hifonics hfi 100.4 mids and highs.
hifonics zeus 6.5 separates 11mm tweets.
3 300 amp fuses, 0 gauge wire.
yellow top optima in front and back.
alpine head unit.
I would use a 250 amp fuse. I like to have a little headroom in my fusing exspecially if my amps have built in fuses.
only tha bass amp has a built in fuse but tha 4 channel amp dont.
Then you will need to add another fuse right before the 4 channel and for that fuse I always stick to the manufacture's recommendation.
the 4 channel amp has 2 30 amp fuses on the outside and the bass amp has 140 amp fuse on the inside, so y do i need a fuse be4 tha 4channel amp?
This means that they both DO have built in fusing so you don't need to fuse right before the amp.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
If I'm not making sence then I can't help you.
Is you're power wire atleast 0 guage?
Because i wouldn't put 250amp fuse on 4 guage wiring it will burn.
i understand wat ur talking about i just dont know wat ?'s ur answering.
so wat ur sayin is i need a 250 amp anl fuse right?
alpine head unit.
Yes :)
its actually 2 gauge.
alpine head unit.
Yes :)
thanks 4 tha info.
alpine head unit.
You will need to find out what size fuse to use with 2 gauge. Its fairly rare so I don't know what size to use with 2 gauge.
4 gauge takes a 125 to 150 amp and 0 gauge is usually rated for a 300 amp fuse. 2 gauge would be somewhere in the midde of that range.
  • Who's Online   0 Members, 0 Anonymous, 2473 Guests (See full list)
