hibatch Posted March 22, 2011 Report Posted March 22, 2011 Hey guys, I have a Kicker 750.1 that i got from a friend. He said it worked fine when he had it but now that i have it its not (i think he lied sob). I hooked it up just like i had my infinity amp (that works fine on my sub), Ive swapped both out multiple times and the infinity works but the Kicker wont. When the kicker is hooked up it powers on with the green light and stays on but I get no power to the subs. I made sure the RCA's, and wires to sub were hooked up correctly and they were. any ideas of what the prob may be? Hibatch 6.5 infinity components 6x9 infinity coax infinity 611a amp 2 13" JL w3's ported Big 3
Superjay Posted March 22, 2011 Report Posted March 22, 2011 is there a slave/master switch? are you sure you connected the RCA's to the input? Principal JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
hibatch Posted March 22, 2011 Author Report Posted March 22, 2011 the RCA's are connected to the input, would the master/slave be inside the amp on the board like on a computer? there is no master/slave on the outside. Hibatch 6.5 infinity components 6x9 infinity coax infinity 611a amp 2 13" JL w3's ported Big 3
Superjay Posted March 22, 2011 Report Posted March 22, 2011 no it wouldn't...pull the amp and bench test it...just to be sure there aren't any anomalies the Infinity performed around, but the Kicker doesn't like. Principal JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
hibatch Posted March 22, 2011 Author Report Posted March 22, 2011 what do you mean bench test it? I also have a small mtx amp that works just fine as well. neither the infinity or mtx have ever had probs. Hibatch 6.5 infinity components 6x9 infinity coax infinity 611a amp 2 13" JL w3's ported Big 3
TeamHT Posted March 22, 2011 Report Posted March 22, 2011 whata subs and what is it wiring to at the amp? Tell me...does this smell like chloroform to you?
hibatch Posted March 22, 2011 Author Report Posted March 22, 2011 whata subs and what is it wiring to at the amp? I have a 2 10 kicker cvx's one is dual 2 ohm and one is dual 4 ohm. right now im only using the dual 4 ohm. im trying to trade or sell the dual 2 ohm. im wiring the 4 ohm down to 2 ohms. Hibatch 6.5 infinity components 6x9 infinity coax infinity 611a amp 2 13" JL w3's ported Big 3
hibatch Posted March 23, 2011 Author Report Posted March 23, 2011 anyone have any other ideas as to what i can/should do? Hibatch 6.5 infinity components 6x9 infinity coax infinity 611a amp 2 13" JL w3's ported Big 3
dthomas Posted March 24, 2011 Report Posted March 24, 2011 Sounds to me like the amp has problems. You have already tried 2 other amps that work fine, so you obviously have Power,Ground, Turn on and Signal.
