Okay, this is for you guys who have been doing this for years, experience every sub, and every kind of box. I've ordered two FI BTL N2 12" subs. The website suggest 1.7cu feet to 2.5cu feet of space, tuned at 32hz, with 12 to 16sq" of port per cubic foot. On the several boxes I've built, I've always maxxxed out the cubic feet as much as possible. Now I have a Focus, and space is limited. I am trying to build a box tuned low, so I need alot of cubic feet. But, the most I can possibly get w/out having to take off panels and still have room for xtra batts and my two amps is 3.43cu feet tuned at 32.16hz with 12.76sq" of port per cubic foot. Now, I'm not worried about the tuning or port area, but I am a little worried about the cubic ft of the box. I know it is in the parameters set by the specs, just barely, but I am worried it will not achieve the deep, low bass I desire. Could someone help me out and let me know if you would recomend doing this, or if you would go a little bigger. I can achieve just a slight more bit of area, possible 4.5cu ft at the most, but then I would have to get creative with mounting the two AQ2200's and the AQ4x90. Thanks in advanced you guys...i always appreciate your knowledge and help.
I don't see why it wouldn't get low (especially with that port)...itll probably just be peaky
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
What do you mean by that?^^^
And sorry guys for the double post...didn't mean to, lagging computers fault.
By peaky, I mean that some frequencies will be a lot "louder" than others.
LMFAO so true
:blush:
^^^any way of knowing which frequencies, or is it one of those things you just have to play around with and test out?
Edited by BakermanINC
try aero ports? thats my suggestion
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Didn't really have the room...i'd need to go external to get the tuning i'd need, and i just don't have the clearance for it.
play around and test out. my box turned out to be VERY peaky (it was a sealed box originally for a single JL 12 then adapted to fit a DC 12" level 2 and ported). WHen I made the trip to Ricks shop, we TL'd my set up and it peaked at about 51hz. SMall box and small port, sounds good though!
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
F150:
Stock :(
Processor: DSR1
