ok if i run two runs of zero gauge for a 1000 watt fourchannel amp. and for a 3000 watt mono block would a 300 amp fuse and a 100 amp fuse be good enough. or would i have to look larger
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
depends on the amps in question. There are class a class a/b class d class t etc etc etc. there are amps that do rated and then some that dont. what are the fuse ratings for said unnamed amps? I bet they'll tell you what you need to fuse at. a 1000 watt 4 channel is a pretty big four channel. 250 watts per channel yikes.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
The amount of runs depends on current draw/demand
Fusing depends on wire.
What amps and brand of wire are we dealing with?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
id like to try for tsunami. or knux hyperflex wire ( i think thats right). not sure what class amps yet. idk about the 1000 watt fourchannel i'm just looking at the max for what i might run. i'm thinking of a 3000 watt crescendo but i'm open to others.
  • Who's Online   0 Members, 0 Anonymous, 583 Guests (See full list)
