XS Power
would it be possible to fit two d3100's under the hood in a 2002 chevy silverado 4.8 v8. or would i have to mount one in the cab. im looking at 1 d3100 as a main and partially for the system and the second d3100 for the system only
they can both fit under the hood but you will have to modify the battery tray meade has 2 under the hood of his tahoe and its the same body style
Pretty sure he only has 1
1 d3100 will fit with some work
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
would the d3400's be able to handle 4000 watts with 1 as a primary batt?.
your right i forgot that he had the intake on the other side
op if you truck has a battery tray on the passenger side 2 will fit but again it will take some work i know when i had my 99 tahoe it had 2 battery trays but i only had one battery :pardon:
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
yeah thats why i was wondering it does have the plate for two batts id just have to modify the plate and the wireing hopefully. if not ill run one d3100 and 1 d3400
Do you have an upgraded alt?
planning on upgrading to a 280 amp dc. or i might possibly do a dual alt bracket. and i just found out my truck dosnt have the dual battery pans. i was thinking of my dads avalanche apparently
Edited by bass_stalker
D3400=2500watts as primary and 4000watts as secondary
  • Who's Online   1 Member, 0 Anonymous, 1499 Guests (See full list)
