Mr.P P-loder....153.7 at 36hz 4 15's 4th order or soemthing
Yessir, i need to talk to rusty about it actually, i was hoping i could run leads from his sampsons to the explorer, so i can see what it does on some serious power...that way i could adjust the port on full power...
BUT im at the point now where i dont want to wait, i think i am going to just start glassing the sonotube in. The way i figure even with the high frequency peak, i can run alot less power and be very very very loud. If i have to i will just cut the sonotube out. Will not be fun tho!
Either i keep it how it is (ugly and a flexing port tube) and do it 100% right and strive to adjust my bandwith a little lower, or i start glassing and bracing and get this shit looking gooooood :yahoo:
DCAUDIO
BALLS DEEP
your #101 dawg
nahh check the main thread though because the first post doesnt count thats where the post started if you go check.
click back to home page then look at this threads count lol
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
This build is INSANE........ I'm digging that adjustable port and butter-smooth box interior. Nice work.
It needs a shit ton more work, hopefully im moving back to the bay and live ABOVE the shop, shit will get done quick then. :popcorn:
DCAUDIO
BALLS DEEP
It was at lowes today and yes it does a hairtrick :clapping:
Only on the 30hz tho so far, also its louder on the ipad than playing usb that might be a problem unless i get ahold of a 360.2 asap. kasey offered to let me do some of the glasswork at his pad so hopefully i will jump on it or do it at the shop.
in for teh vidz of nightime 30hz hairtrick :peepwall:
DCAUDIO
BALLS DEEP
http://www.youtube.com/watch?v=pLvB4s2zoZU
Not much but for 2kw and 4 15s....ALSO its way louder today i sealed and starting glassing the sonotube and holy crap what a difference, i didnt realize how much the sonotube was flexing before...
also had a handful of issues after lowes...
so i sillyconed it in for a bit i plan on peeling it all off and using window weld on the backside when i get a down day...which is like never...
ALSO found the source of my passenger window rattle,
I fixed that with a HUGE washer and some silly cone also ;)
Oh and the door still buzzes and rattles like a MOFO...not sure why really...maybe just the door panel itself.
ALSO spent about 150$ at tap and started a layer with the knipex or whatever its called, going around the top and bottom of the sono inside the box and just put a couple strips of mat around it to see what it does. This stuff soaks up resin like no other completely wetted out and i can tell it could use more! But! the side panels are F%$# SOLID so is the joint to the roof.
I am not very good at fiberglassing but its strong and getting the job done! :yahoo:
DCAUDIO
BALLS DEEP
ugly exploders are loud exploders
R.I.P!
(Nov-29-2009)
92 explorer
current build
