Mr.P P-loder....153.7 at 36hz 4 15's 4th order or soemthing
No i wouldnt dare play over 60hz man that is deffinately not cool, not only do you get out of bandwith weird harmonics, i dont think my level 4's would like...
There's nothing wrong with sending a subwoofer 120hz.... Full tilt, no.... you can throw it on a TL at 1/4 volume from 20 hertz to 120 and your subs will be fine.... and you'll get a base range of numbers to see how far out you actually are.
As far as the amp goes.... .3 @ 9v .... You are definitely stress testing that fucker.
not cool? I dont understand. subs are meant to play that freq. what harm can it do? your box looks like it would play it no problem.
That would be some heat right there my man
Actually the amp is struggling right now with the fan intermittently quitting?
I tested all the fets and caps on the board all is well but i got some popping from the subs (was at low volume) and the deck shut off.
I thought it was an rca problem, but pulled the amp out and tested the board before i powered it back on.
Powered it on with no signal wires and didnt get any popping, but the fan on the board was squeeling and "sputtering".
So before i go beat on the borrowed amp anymore im taking it to a pro with a current limiting test bench to check this thing out and maybe replace the fan.
DCAUDIO
BALLS DEEP
Oh it never protected and my deck is on its last leg, but no since taking chances...
So, i think this bandpass just needs to much power, and i do not like how my batteries will have to be setup...
16 12's? :pardon:
DCAUDIO
BALLS DEEP
still confused.... how do you really know your peak unless you do a sine sweep! boxes that have ports have two peaks. one is bigger than the other, just a thought!
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
it doesnt do much good... the highest freq u can burp with in db drag is 79hz.
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
working on sketchup for 6 15s clam :drinks:
would put the wall about 5" forward which means i can bus bar my group 31's (finally) :drinks:
Still want to hit the 4 15s on 9k at .3 if anyone has one all setup :pardon:
DCAUDIO
BALLS DEEP
Youre never satisfied are you? :drink40::yahoo:
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
