ok i just put in my new substage, and have never really had rattle problems, but now there pretty bad. Does anyone know how/what tool to use to remove the trim panels of a 95 chevy truck, ext cab. Mostly the back plastic that goes across the window, and above the window.
pull on it. use a panel trim tool. ill be perfectly honest. it will break regardless. its old and was never anyting but brittle.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
for some reason, i knew you would be the first the post. thanks, i can see how they come off how they are layered, but i didnt want to break them, just trying to deaden and maybe foam some gaps to silence the rattle.
I didnt want to break mine either but i did. the way the tabs are mounted on there they are going to snap. Well at least one of them will. I was using a plastic panel popper and everything took my time and still popped it. you can probably get a new onr from lmctruck if you really want.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Even if a clip or two break, will the pieces fit back on correctly and stay?
im sure it wouldnt be an issue.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Worst comes to worst you could always put a bead of superglue or something behind it to hold it in. Then again I haven't messed with these before so don't quote me, just throwin an idea out :pardon:
Plastic epoxy would be hella stronger than superglue. Just pull straight and as careful as you can.
"WHOEVER SAID MONEY CAN'T BUY HAPPINESS MUST OF BEEN BROKE"
All the rattling is because the port is up, so the back panels towards the top and the single piece that runs across the top is rattling.
Could I do like a shim or something to prevent them from moving?
sides come off then the top..
takes hella ninja skillz to not break them.
  • Who's Online   0 Members, 0 Anonymous, 1112 Guests (See full list)
