Ok so I have a Rockford T4000 bd on the spec sheet it says 4300 or something like that at 14.4 volts. So m question is after setting my amp gains to no clipping do u still get the 4300 watts or no ? Does it depend on the amps ? Help plz
You won't ever see 4000 watts, let alone 4300watts 99.8+% of the time.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Youll possibly get 50watts total at some frequencies. You need to test in order to find out.
LMFAO so true
:blush:
yep after voltage drop, impedence rise. resistance, lots of variables..
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
Wouldn't he have to stay at 14.4 volts or higher all the time and not drop volts at all to stay as close to that wattage?
MANY more things affect output wattage than voltage.
LMFAO so true
:blush:
even then it wouldnt matter. your lowest impedance will be at least 4ohm. then itll have spikes above 10ohm. plus music is dynamic. so the best power you will likely get is 2000w. its not a trick or a rip off, thats just how audio works. as long as you are not clipping, your subs should be fine.
