you can get 300 amp fuses for 1.50 - 2 dollars a piece, plus they rarely blow, if your blowing fuses you really should have another run of wire anyways
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
i didnt read any of this thread just wanted share this info with whoever wants to listen
my friend had a circuit breaker malfunction and went up on fire and bamn 6 level 4s dead and half his blazer
R.I.P!
(Nov-29-2009)
92 explorer
current build
they rarely blow because most people arent sending 300 amps of current through their wires, so in theory you have too big of a fuse, so really you could fuck something up without the fuse even popping at all
Car: 1995 Thunderbird
System:
Pioneer deh5100ub HU
Pioneer/Lightning Audio 5x7's
1 Hifonics 1610D amp
2 Obsidian Audio 12's
4cu.ft. box tuned to 30hz
8 farad Boss Audio cap
4 gauge power/ground wire
Youtube
Facebook
Sh!t, i need to check my topics more often. Thanks for the info guys. If i was going to use them it would of been for my amps. I would of properly fused the battery's. Ill see what i can get a better deal on and go for that. :good:
If I'm goin to hell, I'm going in a HOLDEN!!!
Speed doesn't kill, Its the stopping suddenly that gets you.
Quoted by the one and only Jeremy Clarkson.
Build: A Secret!
Fuses aren't there to limit current draw, you can easily draw more than 300 amps through a 300 amp fuse in a short burst, but they aren't meant to pop from current draw, they are meant to pop from heat. If your power wire grounds itself then it can get hot enough to start something on fire, that's what the fuses is there to stop.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
I used circuit breakers instead of fuses. Like someone else said, if everything is right, and your not constantly flipping it back on, then they work fine. Houses use them, and w/ a lot more current than is in our cars. Sure they can f*ck up, but so can a fuse. If they were THAT dangerous, everyone would still have fuse boxes in their house. And yes, houses AND cars have burnt b/c of breakers. But they have also burnt b/c of fuses, too. My opinion is, if you do it right, either one will work fine. It's more a matter of what you want.
BTW - pm me if your still looking at them, I have 2 extra 200a Stinger cb's I'll let go pretty cheap, and they are still brand new in the box.
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
  • Who's Online   0 Members, 0 Anonymous, 1036 Guests (See full list)
