using diodes to step up voltage
Sheeeiiittttt! No problems? Smoothe sailing?
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Anyone still doing this? trying to figure out the sensing wire for my 99 jeep cherokee 4.0
My friend had a 1996 Cherokee with the 4.0 and it was externally regulated from the factory. Had a field terminal and everything. If that's the case with yours you could just get one of the blue transpo regulators and wire it up
http://www.motorcityreman.com/13advore.html
Only reason I ask: Are you sure this will work for you?
  • 2 years later...
I know this thread is old but i found something that might be useful
i have gotten the diodes to work on mopar alts, i have a 05 pacifica and the alt only has the 2 field wires
In my case i tapped into the wire from the fuse box to the pcm (in my case fuse39 org/red wire) that is unswitched with ignition
the pcm reads and adjusts your voltage based on this wire
it's a 20a fuse so i used a 30a Schottky diode
my voltage went from 13.6 to 13.9 hot (still 13.6 at pcm)
I'm going to order some more diodes from mouser to do a bit more testing
  • Who's Online   0 Members, 0 Anonymous, 1266 Guests (See full list)
