using diodes to step up voltage
As long as NO ONE hold me accountable for their actions that's fine. I'm sure if done carelessly the outcome could be catastrophic.
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
Its ironic that the LED for battery voltage is red haha
Its orange, at 15.6 its red. RF amps shut off at 16.0 :( I had one the was 15.6 volts warm but cold was ~16 volts and my amps wont even turn on lol.
No, I know why it was orange. I meant that it was ironic because orange/red means bad, but your voltage was wonderful lulz
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Can you go into a little more detail on how you made this, I run dual alts and might try this on my OEM one to see how it works.
I would NOT recommend doing it on ONE alt and not the others. If I understand correctly, If the regulator see higher voltage it turns itself down so in theory you would be cranking the others done defeating the purpose. THIS DOES NOT INCREASE AMPERAGE...
Subs: 2 T1 12's
That's just RF being pansies ;) Im sure they have their reasons, I just know that my stock alt would drop the needle into the LOWER red side, so now its on the HIGHER red side ;)
Subs: 2 T1 12's
Atleast the needle is on the other side :)
Constant Powa and those needles > 16+ volts imo lol
LMFAO so true
:blush:
Here is how I did this. USE THIS AT YOUR OWN RISK.
Subs: 2 T1 12's
Gotcha, I can do it on both alts then, just wanting to find an alternative to the VCM, since aren't in stock.
I know right :(, thanks to them being out of stock I made it my self LOL. This trick and a Stinger Voltage gauge and your all set. Using different size diodes will allow for a fine tune as well.
Subs: 2 T1 12's
these are truly the best amps I have ever owned. Having matching amps is sexy by its self, Now add the needles and its sex. People love them until I say 1899.99 EACH lol.
Subs: 2 T1 12's
You may also want to recommend people not to connect the battery until you check the alt charging voltage.
People may not want to risk their 12v battery getting like 17volts. I know you said what resistors and alt you have, but the resistors may have different results on different alts. They also might try different size resistors.
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 1794 Guests (See full list)
