using diodes to step up voltage
yes thats wut i figured so i will have 12 amps if put in series and then i can use the pot to turn it up and down
2015 silverado crew cab
nothing atm but soon...
la negra are you sure ones not a dark red and just a little dirty cuz from what i found ones red and ones brown. the red wire is the sense wire according to this diagram
fecupe i need a picture of your alternator wiring. i believe this is the right one but not 100 percent sure. if it is then it should be easy
white/black wire is your sense wire and it just loops back into the alt
the wire that is inside the yellow is the sense wire for a ford 3g alternator. i believe your alternator is the same and the diode should go between the 3 wire harness and were it plugs back into the alternator. this one is different so im not totally sure how the ford alternators work. remember your doing this mod at your own risk of screwing up your car
ill take a good look at it tmrw when its not dark outside but idt its dirty
let me know and take a pic if you can. im just tryin to help if i can. it may work it may not
also fecupe can you take a picture of your alternator for me
deeje: i just looked yours up and your sense wire is also the white wire like bdubii's
Ok cool so just cut the white wire stick a diode or 2 in the middle then reconnect it?
--2004 Toyota 4runner
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
spl dust is an option you can get on the coils... it's great for extra 1000 watts of power
where can i get this spl dust and how much is it. is it hard to apply? lol
yes look back at the pictures on the other page. you just slpice it and add them in
Aright cool thanks.
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
I'm so glad this has helped so many people, I can't beleave no one figured this out before me. If they did they should have posted like I did.
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
