'91 Civic hatchback wall build
Even for those to be entry level they're still nice
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
moar :drink40:
Thanks for the comments, guys.
Ok, we decided we wanted to go all the way to the ceiling with the baffle, to ensure that we have enough room for subs to be stacked 2-high. The top of the box was going to be about four inches from the headliner at the front of the box, because the roof slopes down as it goes toward the back of the car. So we had to make an "add-on" to "raise the roof" of the box at the front, near the baffle:
Test fit:
This will add about .8 cubic feet to interior box volume. We already had the recommended 16 cubes that DD says is optimal for these subs, so now I guess we can add extra braces to make up the difference....
ftw. btw is this close to done arleady and your just holding out on pics?
I hope so. We almost went with Alpine Type R's, because I've heard a lot of good about them, but then the owner of the shop we use recommended these instead. They don't cost that much more than the Alpines, and he says they will be well worth the difference in price. Being as how I've never actually heard either woofer in use (in real life anyway), I am pretty much taking his word for it. We'll see......
You will be happier with DDs over Alpine.
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
A little painting:
Added some 2x4 baffle braces, as well as a double layer on the back wall, and a front-rear 2x4 brace:
Starting on the baffle:
Router jig I made:
I cut out an inset to hold the router tight, so I don't have to bolt it down:
Works like a charm:
Finally starting to look like something:
Baffle is just sitting there, not attached yet.
This is pretty much where we are now. Started running zero guage to the back of the car, but don't have the batteries installed yet. Still need to figure out something for amp racks and trim panels back there, but concentrating on finishing the box first.
We are taking our time, trying to do things right, till funds allow purchase of the other two woofers and the amps. Hopefully within the next week or so. Until then, I'll update as the build continues.
Great build so far. How thick are you going to make the baffle?
It will be 1.5 inches thick (2 sheets of .75" MDF). With all the 2x4s behind it, I really don't think it will flex much. There are supports all the way around each woofer hole, never more than a few inches away.
  • Who's Online   1 Member, 0 Anonymous, 1093 Guests (See full list)
